Speed signal input
Old Aug 15, 2010 | 01:28 AM
Darksythe's Avatar
Darksythe
Default Speed signal input
Where is the place to tap into the speed signal input? I need it to finish the install on a pioneer z110bt. Could'nt get a response over in the audio section lol. Thanks!
Old Aug 15, 2010 | 02:35 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Did the same install last January. IIRC, I took it from a harness in behind the instrument cluster. I'll see if I can find my working documents.
Found this thread:
Click here
Old Aug 15, 2010 | 12:40 PM
Darksythe's Avatar
Darksythe
Perfect! That's just what I needed Blue, thank alot!
Old Aug 15, 2010 | 12:42 PM
vette.mix's Avatar
vette.mix
I plan to do this down the road, I need to save this thread
Old Aug 15, 2010 | 12:57 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
its not worth the time and effort to do the speed signal wire.
Just leave it and you will be just fine
Old Aug 15, 2010 | 02:50 PM
Bloodvette's Avatar
Bloodvette
It is a pile of work to get at that wire. I did it for my JVC NX5000 about 2 years ago, but i had to because without that speed sensor, the GPS would not locate your postion. Really stupid actually considering the speed sensor signal is only really required for poor signal areas like tunnels.
Old Aug 15, 2010 | 03:03 PM
DeeGee's Avatar
DeeGee
As the guys say, VSS only covers for working in poor GPS signal areas. You can indeed find the VSS wire behind the IPC. The alternative is to hook up at the PCM. I hooked up my Pioneer AVIC to the VSS:
Jack up the car to access the PCM inside the passenger wheel well. Once you've removed the passenger side wheel now you can see the PCM access panel. You'll have to lay lie under the car to see it.
PCM 2 is closest to you. On the 2000 and up PCM, the vss wire is c2 pin 50 and it's a green and white wire. You can see the pin number by squeezing the end of the gray cover and releasing the clip and moving the cover to the side.
I used an inline connector to splice into the wire.
Old Aug 15, 2010 | 05:16 PM
0Double D Mods
Former Vendor
Kenwood doesnt need it and the Pioneer radios do not need this as well. So maybe this was something to do with the JVC GPS
Old Aug 15, 2010 | 09:12 PM
Blue Blood's Avatar
Blue Blood
But don't you need to access the VSS wire in order to do the bypass? Otherwise all navigation must be done with car stopped and I think DVD is not available with car in motion...
Old Aug 15, 2010 | 09:16 PM
hattitude's Avatar
hattitude
With the Kenwood, you just put the emergency brake wire to ground.... then you have full control at all time.....
Old Aug 15, 2010 | 11:10 PM
Darksythe's Avatar
Darksythe
Well that makes the decision a whole lot easier From the sound of it ill just hook up the parking break lead and be done with it!
Old Aug 15, 2010 | 11:31 PM
0Double D Mods
Former Vendor
YEP
kenwood take the green parking wire and black ground and run it to the black ground in your harness your using.
Pioneer is a little different depending on the unit
let me know if you need more info as I would just need your model number
Old Aug 16, 2010 | 11:17 AM
Darksythe's Avatar
Darksythe
It is a Pioneer AVIC Z110BT. From the looks of it I have a light green wire with a splicer on the end of it, It says to clamp down on the power supply side of the parking brake. What color will the parking brake power supply wire be? And thanks again as always for your help C5
Old Aug 16, 2010 | 11:32 AM
Blue Blood's Avatar
Blue Blood
For the Pioneer unit, the bypass is a little more involved. IIRC, I had to insert the green wire into the same harness that the VSS is on but I don't recall where, I wish I could remember more.
Old Aug 16, 2010 | 11:57 AM
Darksythe's Avatar
Darksythe
Well I was going to bypass it originally but I had recently heard that even WITH the bypass, the GPS will shut the "bypassed" functions at a 10 or 20 MPH mark anyway. So I had decided not to bypass it if it just was going to shut down at 10 mph anyway. My info could be wrong though.
Old Aug 16, 2010 | 01:30 PM
DeeGee's Avatar
DeeGee
Not sure about your unit I'm afraid. With the AVIC N1 and N2 the ground trick worked. Dont think it did with the N3.
Most of these systems also have a prediction mode. If you watch the display it tries to follow the road on the loaded map until it realizes it's off road and it then jumps back to the actual GPS position. All the VSS input does is predict where the system thinks it is if the aerial can't see the satellites.
I tend to agree that the hook up is more effort than its worth for the average user.
Old Aug 16, 2010 | 01:37 PM
DeeGee's Avatar
DeeGee
What you're doing by hooking up that wire is telling the head unit whether the e brake is on or off. Off stops you adjusting the functions that Pioneer don't want you playing with when the cars moving (legal stuff). On lets you play with all the functions. Grounding that wire lets the unit think the E Brake is on.
I wouldn't recommend watching DVDs on the move but being able to play with the nav functions is quite useful.
Even if you do hook it up, just putting a notch of e brake on achieves the same result.
To Speed signal input
Old Aug 16, 2010 | 03:12 PM
Darksythe's Avatar
Darksythe
Really? So just putting that wire to a ground somewhere in the car would work?
Old Aug 16, 2010 | 03:27 PM
DeeGee's Avatar
DeeGee
It depends on the unit. On my original AVIC N1 it worked. Then Pioneer worked out that people were bypassing the "safety" mechanism and put a software fix in to prevent it. I'm not familiar with your model but its worth a try. If it doesn't, you can still crack a notch of E Brake and achieve the same effect.
Old Aug 16, 2010 | 04:06 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i know all about the DIY thing, but i just didn't want to half disassemble the interior of the car to get to speed sensor harness behind the instrument cluster when i installed my pioneer z110. my local stereo shop (who i had dealt with in the past and whose work i was very comfortable with) was more than happy to do it right (for a charge of only $50.00) and i felt much more comfortable having them do it. BTW you'll love the z110 and you might want to consider the software upgrade pioneer has to make it just like their latest model (z120), once they reduce the price for it (hopefully in a couple of months). the graphics are very much improved, etc. check it out here: http://avic411.com/
