Erratic Headlight (up + down repeatedly)
Old Aug 17, 2010 | 03:55 PM
Freshman's Avatar
Freshman
Default Erratic Headlight (up + down repeatedly)
I purchased a 02 EB Z06 saturday morning 8/14 (36k mi). Everything has been great untill I left for work this morning. When I turned the headlights on both came up just fine (as they have been), but then the drivers side headlight dropped down. So I turned them off, the passenger side light dropped down fine, but the drivers side light popped up and then dropped down. I did this a few times, and the exact same thing happened.
Now when I turn the lights on the passenger side pops up as it should, but the drivers side goes up, then down, up, then down, and continues to repeat. There is no grinding sound in the up position or down postion(believe the plastic gear is still ok).
I have read that there is a headlight module that could be suspect or possibly a bad ground. has anyone else experienced a similar issue???
Any advice or direction would be much appreciated. Thanks in advance.
-Dan
Old Aug 17, 2010 | 04:25 PM
CorvetteRecycling's Avatar
0CorvetteRecycling
Former Vendor
It sounds like a headlight module to me.... If you decide you need one we have them.
http://www.corvetterecycling.com/product_p/16523917.htm
Old Aug 17, 2010 | 04:38 PM
Freshman's Avatar
Freshman
Are there 2 headlight modules, 1 for drivers side and 1 for passenger side??? If so can they be swapped, side for side to see if the problem follows the module?
Old Aug 17, 2010 | 07:26 PM
Freshman's Avatar
Freshman
What does the headlight module do? Does anyone know if there are 2?
Old Aug 17, 2010 | 08:30 PM
warpster's Avatar
warpster
Go here
http://forums.corvetteforum.com/c5-t...al-on-dvd.html
and download the manual, install it and start troubleshooting, it's all in there.
Hopefully someone with prior experience on this topic will post but in the meantime, this is a good start. You could also do a search.....may turn up something.
Good luck....
You can also look here...http://forums.corvetteforum.com/c5-t...d-no-hl-2.html
for the troubleshooting steps and a partial schematic from the manual.
Old Aug 18, 2010 | 11:52 AM
0CorvetteRecycling
Former Vendor
There is one module for both headlights. It is located in the bracket for the Rh headlight.
To Erratic Headlight (up + down repeatedly)
