Gunked up radiator record...
Old Aug 21, 2010 | 10:49 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by killain
Hope you changed out your DexCool @ 50K MI or five year mark. Mine runs about ten degrees cooler with a DexCool flush and refill. And I'd insrtall one of those air intake grills to keep any future trash/ leaves out of the radiator area.
Any links or pictures of the air intake grill mentioned?
Old Aug 21, 2010 | 01:24 PM
robsc501's Avatar
robsc501
Hi There devnull,
You are the man! I was wondering if you have to pull the fans from the bottom front or what? Pita? Post a step by step procedure if you recall.
thanks
robsc501
Old Aug 21, 2010 | 03:07 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Originally Posted by robsc501
Hi There devnull,
thanks
robsc501
Hey thanks bud!
I will post a step by step tonight when I get home, but the fans come out through the bottom (you remove the stabilizer bar bushings to clear the space. Not too bad unless you are slammed like my car is!
Old Aug 22, 2010 | 12:51 PM
MSG C5's Avatar
MSG C5
While working under the car yesterday, I cleaned out my radiator air intake area behind the flex spoiler. Used my hands and shop vac to pull out most of the junk. It was pretty clean though.
Has anyone installed any of these mesh intake protectors? I see these on various vendor websites for around $50, however it looks like something that could be purchased at Home Depot for about $10. Just wondering how to secure it?
Old Aug 22, 2010 | 02:27 PM
robsc501's Avatar
robsc501
Hi There,
That looks like a heavy gauge aluminum. I would bend it to match the conture of the lower fascia.You might have to use a brake, if you can not o it by hand. I would then make cutouts to accommodate the use of the lower fascia 7mm bolts to secure it.
robsc501
Old Aug 24, 2010 | 11:39 AM
MSG C5's Avatar
MSG C5
Hi There,
robsc501
Do you think the screen idea (pics above) would hinder the airflow? Looks like a pretty good/clean solution to keep out the larger junk like bags, leaves, etc. It attaches using the existing fascia bolts. Anyone have this installed?
Old Aug 24, 2010 | 06:46 PM
robsc501's Avatar
robsc501
Hi There,
No I don't think it will affect air flow. If you are worried keep a sharp eye on your coolent temp. I have the eliteengineering screen on mine. custom fit & excellant quality.
robsc501
