targa top shade insert
Old Aug 19, 2010 | 12:14 PM
97c5vette's Avatar
97c5vette
Default targa top shade insert
I'm interested in getting an insert that I can put in my tinted targa top.
I think they are held in with clips or suction cips?
Anyone heve one you can sell me or maybe refer me to a forum sponsor that can help.
Bruce
Old Aug 19, 2010 | 01:07 PM
dcandel's Avatar
dcandel
Oldtimer
I just ordered one from Mid America but didn't like it so I sent it back. The underside (cockpit side) was nice black headliner material, but the upper side was white and visible through the acrilic top. I also didn't like the way it mounted. It had strips of plastic that were to slide under the molding between the molding and the top itself. No clips. I have seen some advertised made of plastic that adheres to the underside of the acrilic top, like window tinting material. Can't remeber where I saw it, maybe Corvette Central.
Old Aug 19, 2010 | 01:11 PM
imavettegirl's Avatar
imavettegirl
it adheres for a minute or so.
do not waste your money.
no good substitute for a solid top.
Old Aug 19, 2010 | 03:56 PM
jrose7004's Avatar
jrose7004
I don't even have the lexan top anymore because in Oklahoma it just gets too hot. I just run the solid top.
Old Aug 19, 2010 | 05:06 PM
TraceZ's Avatar
TraceZ
It would be easy to have a local upholstery shop make one for you.
use cardboard to make a template and have an upholstery shop build a headliner from it. Hold it in with a few small circles of industrial velcro. (the velcro that's plastic and actually locks together, not the fuzzy stuff)
Old Aug 19, 2010 | 06:18 PM
Blew by you's Avatar
Blew by you
People! they are 59 bucks! i got mine from West Coast Corvette's.
Old Aug 19, 2010 | 06:42 PM
nmacdonald's Avatar
nmacdonald
Not sure which one you're talking about from MAM, but I have one that fits great and lowers the temp significantly. It's black on both sides and from the outside you can't tell it's there. I like it. The plastic "clips" work well and if installed carefully present no problem.
Old Aug 19, 2010 | 06:47 PM
Blew by you
That sounds like the one i have and theyr'e great!
Old Aug 19, 2010 | 07:03 PM
bronsin's Avatar
bronsin
Just use the cardboard one and put the $$ in the tire fund!
Old Aug 19, 2010 | 08:49 PM
Blew by you
Jeezus man are you serious!??? you would put a piece of cardboard in your vette? man i feel sorry for your car!
Old Aug 19, 2010 | 09:00 PM
bronsin's Avatar
bronsin
Just think of all the attention you would get!
Old Aug 19, 2010 | 09:06 PM
Both Mid-America and Ecklers sells the inserts for the clear targa top.
Old Aug 20, 2010 | 07:18 AM
dcandel's Avatar
dcandel
Oldtimer
MAM must have changed vendors. I ordered it in May, they were out of stock until 2 weeks ago when it was finally delivered. Black cloth on the down side, and definitely white on the "top" side with the stitching visible. The "clips" were thin pieces of plastic which were to slide between the top and the molding. Not really "clip" mounting.
Old Aug 20, 2010 | 10:22 AM
redrckt97's Avatar
redrckt97
I bought the "film" one from MAM which is static cling. It has a kind
of honeycomb design that really has helped a lot with heat - not as good as a full liner but much better than without - and this is in south Texas where is has been HOT all summer. It still allows some visibility from inside. Mine has been on for 3 months now and no sign of it coming loose. $24.99 -- very happy with it (and it is barely visible from outside)
Old Aug 20, 2010 | 03:22 PM
bucwheat's Avatar
bucwheat
That is the top I have only mine is black on both sides,love mine and it keeps it cooler in the summer for sure.
To targa top shade insert
