2001
Old Aug 22, 2010 | 10:40 AM
TerryC5's Avatar
TerryC5
4th Gear
Default 2001
My 2001, the passenger headlight will open as it should, the driveers side will open sometime...if I tap on it, it will open....also, my car has black over torch red interior....can't seem to find out anything about this, custom order, option???
Old Aug 22, 2010 | 10:54 AM
Jet-Jock's Avatar
Jet-Jock
Sounds like the head lamp motor is going south. Very typical problem with this motor as it has not changed since 1984!.
The plastic gear inside breaks down and the options are rebuilt the motor with a brass gear (under $30 + time) or replace the motor ($160. plus a little time).
Do a search in C5 General for headlamp motor gear and you'll find plenty of info including instructions on how to service it. Might as well plan on doing the other side they usually go about a month or two apart.
Do you have the owner's manual? If not there are places to download a PDF version.
If you want the individual dealer brochures, join NCM (National Corvette Museum or not) and order the factory window sticker and dealer brochures for '01 and your vin.
This will get you started: http://forums.corvetteforum.com/c5-g...ngths-etc.html
Review the pages on this sticky and you'll be more informed.
Welcome!
Old Aug 22, 2010 | 11:02 AM
TerryC5's Avatar
TerryC5
4th Gear
Thanks Brother! I'd seen this fix a couple of times and was hoping that was not it....LOL. I live in Oklahma and it's to dang hot right now to do anything, I'll order those gears and get this going....this is my first Vette and I'm learing that alll things Vette are not simple....also if it has a Vette emblem on it, it'll be expensive!!!
Old Aug 22, 2010 | 11:46 AM
Jet-Jock's Avatar
Jet-Jock
Here's a link for a real original owners manual:
Owner's manual
and the factory service manuals for 2001 Corvettes:
Bible
The factory service manual set is a requirement for those who intend to do your own degree of work. It's the first thing for that Vette I buy. (You'll find it is worth it's weight in gold.)
TerryC5's Avatar
TerryC5
4th Gear
Thanks Again!!!
Old Aug 22, 2010 | 11:49 AM
Jet-Jock's Avatar
Jet-Jock
Sure
PM me with an email address and I'll send you the PDF version of the owner's manual. You can find things quicker in the electronic version
Old Aug 22, 2010 | 11:51 AM
TerryC5's Avatar
TerryC5
4th Gear
blet7210@pldi.net
To 2001
