Low Washer Fluid - WTF!!!!
Old Aug 24, 2010 | 11:47 AM
MyOwn69's Avatar
MyOwn69
Default Low Washer Fluid - WTF!!!!
I don't know that I've EVER used the washer fluid since I'm usually not out on ugly days in the Vette. The last time the message came on I filled up the reservoir anyhow just to get the message to stop!
Then I notice that now and then I'm finding washer fluid under the wiper arms - and then the message starts appearing again!
What's up with that? What can I do to get it to stop? Why would fluid be leaking out of the lines?
I'm open to suggestions - ideas - etc!
Old Aug 24, 2010 | 11:54 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
This is a common issue. I find that when I really get on it, the washer fluid will come out of the wipers. It happens on all our car's.
I also don't drive in bad weather. After 6 years my tank went dry, and the fault light came on. I filled my tank, but the sensor was still showing a fault. I drained my tank, then removed the sensor and cleaned it. I re-installed the sensor and re-filled the tank and its worked fine ever since.
Toque
Old Aug 24, 2010 | 11:55 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Sounds like your running a leak in one or more of the hoses running inside the wiper arm. Probably cracked....having said that, it is a lot of fluid too lose from those little hoses and you wouldn't be drawing the fluid up into those hoses if you weren't constantly hitting the washer. Has to be a leak somewhere else. Are you seeing anything under the car? Take a look at the reservoir. If memory serves me the hose connections to the wiper arms runs from a port on the right lower side of the tank. Could be the leak is starting there. If so, could be as simple as just needing a new rubber washer where the port is entering the reservoir......
Old Aug 24, 2010 | 12:10 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
What are these "Windshield Wipers" that you speak of?!
Old Aug 24, 2010 | 12:16 PM
Ron C!'s Avatar
Ron C!
Well, I just filled mine again. But, I actually use the washers and sometimes the wipers. I commute 52 miles each way, so they get used. What surprises me is how big the tank is when most people never use the washers.
Old Aug 24, 2010 | 05:39 PM
BitViper's Avatar
BitViper
I mixed a bit of vinegar in my tank.. it cleaned off the sensor W/O removing the tank.. Better living through Chemistry
Old Aug 24, 2010 | 05:46 PM
SCM_Crash's Avatar
SCM_Crash
I NEVER use the wiper fluid. I don't think that stuff works well. I change my wiper blades every year to make sure I don't have dry blades just in case it rains while I'm out.
But I keep my windows clean. I wanted to remove the wiper fluid to save a little weight, but I already get that stupid message and there's definitely fluid in the tank. Although, every now and then when I pop the hood to do the ranger method of changing the clutch fluid, I see that the washer fluid is leaking out the cap.
Any way to disable the message so I can just empty the thing?
Old Aug 24, 2010 | 05:56 PM
Omaha02Z06's Avatar
Omaha02Z06
I’ve only used my fluid probably 3 or 4 times in 2 years and that message pops up all the time. I just hit reset. Should just to drain it and disconnect the sensor.
Old Aug 24, 2010 | 10:35 PM
MyOwn69's Avatar
MyOwn69
So you're saying I have to give my Vette a douche??
Old Aug 24, 2010 | 11:06 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Toque
Toque hit it on the head. After driving a bit aggressively, I come home and notice dried washer fluid on the windshield. I have no idea how this happens, but it happens, and it apparently happens on all C5s.
Engineering...sheesh.
Old Aug 24, 2010 | 11:43 PM
jrose7004's Avatar
jrose7004
Old Aug 25, 2010 | 12:06 AM
Trios's Avatar
Trios
Well, you start by disconnecting the sensor. Then, if it comes on all the time, you plug a jumper into the connection to bridge the wires, and that should fix it. Essentially, it just depends on if its a normally open or normally closed sensor...
Old Aug 25, 2010 | 06:19 AM
SCM_Crash's Avatar
SCM_Crash
Gotcha... I may do that. Wiper fluid is a waste in my opinion since I don't see the need for it.
Old Aug 25, 2010 | 07:42 PM
Trios's Avatar
Trios
My C5 is a daily driver in the Seattle area. The reservoir needs refilling every couple of months.
Old Aug 25, 2010 | 07:57 PM
JPM's Avatar
JPM
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Was the Washer Fluid a special option and does Gene Cully have this if I want to upgrade ?
Old Aug 25, 2010 | 08:25 PM
Trios's Avatar
Trios
Aftermarket only, adds 30 HP.
Old Aug 25, 2010 | 08:41 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
You might also want to check the plug that faces the windshield from the reservoir. I bumped mine when cleaning the utters and fluid started to leak out, it is just pressed in.
To Low Washer Fluid - WTF!!!!
