Cags
Old May 10, 2005 | 08:27 PM
6Strings4Me's Avatar
6Strings4Me
Default Cags
Could somebody tell me what.......CAGS stands for ?????
I am in the market for a 2000 - 2002 Coupe
And I see this quite often......is it a brand or type of shifter ??
Old May 10, 2005 | 08:36 PM
speedfreek155's Avatar
speedfreek155
Computer Aided Gear Shift , 1 to 4 skip shift on 6 spd trans .
Old May 10, 2005 | 09:01 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
If you buy a 6 speed, the first mod you should do is the CAGS eliminator. It only costs about $20.00 through Corvettes of Houston and will give you great peace of mind knowing that you can shift into any forward gear whenever you want to rather than when the car's computer thinks it is OK. Not having a CAGS eliminator on you car could greatly increase your chances of being rear-ended when in heavy traffic. The reason I believe this is I almost got rear-ended a couple of times before I bought the CAGS eliminator. Normally I would run through the gears at high enough RPM that the Cags would not kick in, but when in stop and go traffic I would forget about the stupid CAGS and try to shift into second on a slow takeoff and I would be blocked out. By the time I would react and go to fourth or back to first the person behind me who was not expecting me to slow down for no apparent reason would be slamming on brakes to avoid running over me.
Now wouldn't it be embarrassing to get rear-ended in your Vette!
Old May 10, 2005 | 09:07 PM
6Strings4Me
Default Cags
Computer aided gear shifting !!!!!!!
What is this world coming to????
Thanks alot guys !!!
This site is awesome !
Old May 10, 2005 | 09:08 PM
EscapePod's Avatar
EscapePod
I thought it was Computer Aided Gear Selection (or Selector) ???
Old May 10, 2005 | 09:09 PM
AlanN's Avatar
AlanN
I got one but, don't know how to put it in and don't have a lift.
Old May 10, 2005 | 10:10 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
That is correct!
Old May 11, 2005 | 06:53 AM
Its a factory feature that forces a 1-4 shift under certain conditions. It was created to help with gas mileage estimates - but can be defeated by installing a CAGS eliminator part readily available from almost all the vendors and very easy to install. Once installed, the car will shift into second anytime you want. This was the first mod I did to mine.
Old May 11, 2005 | 10:41 AM
pburant's Avatar
pburant
As someone else pointed out, the whole point of CAGS is to increase the cars efficiency during the EPA mileage test.
We should all thank GM for this, because they did it to avoid a gas-guzzler tax, which makes the car less expensive for us. GM also made CAGS very, very easy to defeat - something they didn't have to do. GM has done plenty of dumb and senseless things, but CAGS isn't one of them.
You don't need a lift to install a CAGS defeat (in fact, there really is no such thing as a CAGS defeat - you defeat CAGS simply by unplugging the solenoid on the transmission. The 'CAGS defeat' that you install is a mere resistor that prevents your car from throwing a code when the CAGS solenoid is unplugged). You only need a jack and jack stands - just lift and support the rear of the car - you only need enough room to get under there.
-Pete
Old May 11, 2005 | 10:57 AM
torchredfrc's Avatar
torchredfrc
It's a simple install and can be done with a jack... no need for a lift.
Old May 11, 2005 | 11:00 AM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Does thr 1-4 shift light still come on even if its installed? Mine is done but the light comes on? Is this normal?
Old May 11, 2005 | 11:04 AM
zman3's Avatar
zman3
My light comes on also. As long as it let's you shift into 2nd, I wouldn't worry about it.
Old May 11, 2005 | 11:52 AM
Patches's Avatar
Patches
It's normal if you use the resister CAGS defeat module. I eliminated mine with tuning software so the IP light doesn't come on ever - a side benefit of using software to defeat it.
Old May 11, 2005 | 12:20 PM
DavesC5's Avatar
DavesC5
It is a GM misprint. It was intended to be GAGS.
Old Aug 25, 2010 | 08:11 PM
chicojerry's Avatar
chicojerry
3rd Gear
I have a CAGS eliminator kit from mid-america, with pictures showing what I should be looking for. I looked under the car today, but do not see anything like their picture. Does someone have a picture of the CAGS plug on or near the transmission?
Old Aug 25, 2010 | 09:02 PM
vafirevet's Avatar
vafirevet
It is on the drivers side of the transmission. Blue and white connectors. I think it is the only blue/white connector in that area. It was easy and took two minutes to install.
To Cags
