I've been having fun researching codes and learning about my car.
My car is a 2003 Coupe. It came with RPO codes Z51 (Performance Handling Pkg.) and FE3 (Sport Suspension System). Did most C5s come this way? What was changed from the base suspension?
My car has code FFS, Revised Fuel Tank system. Is this the setup that plagues some 04s?
It has 1SB, the Preferred Equipment Package. It also has 1SZ, which I haven't figured out yet.
I has codes MM6 and MN6. MM6 is the Borg-Warner 6-speed manual tranny. MN6 is Manual transmission, provisions. Am I correct that this code covers the clutch assembly and everything else that differs from an automatic: shifter, transmission mounts, etc.?
1SZ was the Preferred Equipment Savings Group - certain thing were grouped together and the buyer was given a discount.
The Z51 package was an option on the coupe/vert and included stiffer springs and stablizer bars. It required the performance differential for the A4 cars.
MM6 Transmission, Manual 6-speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-speed Provisions
I would assume that the MM6 and MN6 do cover the clutch assembly and everything else that differs from an automatic.
