Service Active Handling
Old Sep 7, 2010 | 05:08 PM
Village1's Avatar
Village1
1st Gear
Default Service Active Handling
On my 2004, I am constantly getting the message to Service Active Handling. I took it to Mr Goodwrench and recieved no help. In addition, the cruise control is frequently disengaging for no apparent reason. Again, no help from Mr Goodwrench. Any suggestions?
Codes are 28 TCS C1287 Steering Sensor Rate Malfunction; and 60 IPC B0521 Tachometer Signal Circuit Malfunction.
Old Sep 7, 2010 | 05:09 PM
dougbfresh's Avatar
dougbfresh
Pull the codes and report back.
Old Sep 7, 2010 | 07:46 PM
Tim01Coupe's Avatar
Tim01Coupe
I had the message constantly and found a corroded ground. Driver's side, near the steering linkage, on top of the frame. But I yield to the previous suggestion, pull the codes first and report back!
Old Sep 7, 2010 | 08:30 PM
herZ06's Avatar
herZ06
i get it too, on my 2001. i just turn that crap off and move on!
Old Sep 8, 2010 | 08:31 AM
50th_Vert's Avatar
50th_Vert
the active handling is there to save your life. leave it on unless your a professional, or your doing a few donuts
Old Sep 8, 2010 | 08:49 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
You need to replace your SWPS sensor. It is located at the bottom of the steering column. Its a $60.00 part but its two hours labor. They DIY is available here on the forumn. I had the same problem.
Old Sep 8, 2010 | 08:59 AM
tricep's Avatar
tricep
St. Jude Donor '09
After about 20 starts (or so) it will go away, but you'll notice that it isn't working.
Get it fixed. It'll keep coming back until you replace the sensor. There are a number of other things that it could be within the system, but I'm sure the codes will have been thrown and available for your viewing pleasure.
It ain't safe to drive w/o. Trust me.
Old Sep 8, 2010 | 09:57 AM
dougbfresh's Avatar
dougbfresh
Silly answer
Old Sep 8, 2010 | 05:50 PM
98blownvette's Avatar
98blownvette
I drive with mine off all the time. If you trust it to help you to drive you are setting yourself up for failure because you can and possibly will get an accident. I do see what others are saying though as to leaving it on for a safety measure. Just don't rely on it to help you all the time, there is only so much that system can handle by saving you. If you are a terrible crappy driver it won't help you.
Old Sep 8, 2010 | 06:04 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by tricep
Get it fixed.
Old Sep 8, 2010 | 07:09 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I don't recall the exact code that caused the same warning on mine but it was related to the steering sensor on the column. I also re-did the ground under the hood and (as suggested in a thread) then disconnected the sensor's harness a few times and reconnected. Apparently it gets some corrosion that breaks the connection.
It is that harness connection down at the base of the column to the left.
Haven't had the code re-appear yet.
Old Sep 9, 2010 | 12:48 AM
herZ06's Avatar
herZ06
my active handling that's supposed to "save me" does just the opposite. It kicks in and puts me in situations that, if I were a crappy driver, I would have crashed when it did. I know it's messed up, I don't have the $ to fix it or care to spend the $ to fix it even if I did have it, so I just turn it off and avoid it. I've been doing this for months... and I haven't had any issues.
Old Sep 9, 2010 | 02:07 AM
98blownvette
I just think its a false sense of security. If you are going to be messing around in your car at least get to know your car then do it. Or do it or practice in school parking lots!
Old Sep 9, 2010 | 06:59 AM
tricep's Avatar
tricep
St. Jude Donor '09
You guys with all the "I don't need the car thinking for me" B.S are delusional.
Sounds to me like you are NOT using your cars as DD's in everyday situations with a lot of weather and a lot of traffic.
I know people just like you who think that way. I have also seen people who think that way lose control of their Vettes because they were remembering how it was "back in the day" with their old Camaros, Challengers, Chargers, Novas, Mustangs, etc..etc..
I would love make an offer for you to show me how you "handle" your cars like some kind of professional race car drivers with the AH off.
Let me grab my video camera while wer'e at it.
Old Sep 9, 2010 | 07:00 AM
tricep's Avatar
tricep
St. Jude Donor '09
you forgot one word: "yet"
Old Sep 9, 2010 | 03:10 PM
kh400's Avatar
kh400
I agree with this writer. The problem with this system is, when it does fail, it applies one of the front brakes suddenly and can create a real problem for the driver. I also leave the sytem off to avoid this happening.
Old Sep 9, 2010 | 03:25 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Possibly how this driver felt too....I dunno...
http://www.kgw.com/home/Beaverton-fa...-97526704.html
This paragraph could indicate this:
Witnesses told police a black Corvette was westbound on Jenkins and barely stopped for a red light at Murray. McGrew turned right onto Murray and accelerated. He lost control, fishtailed across all lanes and crashed into a cement retaining wall.
To Service Active Handling
Old Sep 9, 2010 | 03:41 PM
DeeGee's Avatar
DeeGee
For the OP
The C1287 is, as mentioned earlier, typical of the steering wheel position sensor failing. I have the same issue. If the SWPS shows a fault it kicks out the AH. You soemetimes feel a little twitch as it drops out. The cruise control relies on a functional AH so the trip will kick out the cruise control. Its a symptom of the problem not a cause.
You can DIY change the SWPS but it means pulling the steering column. Not for the faint hearted. You may want a dealer to fix it?
Old Sep 9, 2010 | 03:42 PM
garage-ghost's Avatar
garage-ghost
Amen my friend.
I know some SMART professional race car drivers that never turn it off on their DD.
Old Sep 9, 2010 | 04:12 PM
98blownvette
It doesn't protect you from straight stupidity. Speed and possible alcohol were involved. Again just because you have this doesn't make you a better driver or make the car handle turns at stupid speeds. If you are the stereotypical vette owner then by all means leave it on. But if you got any common sense and know your car you don't need this system.
