[Z06] Tranmission Fluid and Rear Diff Fluid
Old Sep 8, 2010 | 02:34 PM
Metal-Man's Avatar
Metal-Man
Default Tranmission Fluid and Rear Diff Fluid
What kind of fluid should i replace my transmission and rear diff with? Any recommendation and how much should I purchase and what kind of additive? Also how many miles should this be done? The car is a 2003 Corvette Z06?
BTW - What aftermarket stuff does everyone like?
Old Sep 8, 2010 | 03:16 PM
KrispyZ06's Avatar
KrispyZ06
Here is what I changed.....
GM recommended fluid for the trans, red line with no additive for the diff.
Worked good so far, I reccomend the quantitys in the pictures
Old Sep 8, 2010 | 03:19 PM
KCvetteowner's Avatar
KCvetteowner
I like the magnetic tranny/diff plugs....might check them out..
Old Sep 8, 2010 | 06:17 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Old Sep 8, 2010 | 07:15 PM
dbaker's Avatar
dbaker
I run Amsoil ATD in the trans and Amsoil Severe Gear 75-90 in the diff of my 02Z.The SG fluid has the limited slip additive in it.
I change the trans & diff fluids in ALL my cars every 15k.Fluid is cheap....trans & diff's are not.
Here is the link for your car:
https://www.amsoil.com/mygarage/vehi...LET+CORVETTE+S
This guy is good & trusted Amsoil/CF vendor.
http://www.c66racing-synthetics.com/
\db2
Carolina
Old Sep 9, 2010 | 04:49 PM
Metal-Man's Avatar
Metal-Man
Does anyone know the drain plug, rear diff and trans plug magnetic part numbers from GM so I can place the order or know where to get them?
Metal-Man's Avatar
Metal-Man
Thanks for all the help everyone.
Old Sep 9, 2010 | 09:02 PM
JimbeauZ06's Avatar
JimbeauZ06
I use Mobil 1 engine, tranny and rear diff. Phoenix puts it in their T1 race cars it's good enough for me.
Engine oil changed every other track event, tranny at least twice a year and diff at least once per year.
If I didn't track my car I'd use GM fluids in the tranny and diff, and would only change them every few years depending on mileage.
Don't think you can go wrong with any premium synthetic product, but I also don't believe all the hype around some of the more expensive "boutique" oils out there either, but I'm in sales and marketing so I'm naturally skeptical of promotional claims.
Old Sep 9, 2010 | 09:10 PM
AU N EGL's Avatar
AU N EGL
Old Sep 10, 2010 | 05:04 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Amsoil! ,
Old Sep 10, 2010 | 09:13 AM
SCM_Crash's Avatar
SCM_Crash
I use all Amsoil products. Why cheap out on the stuff that maintains the expensive parts?
I use Amsoil Advance Torque Drive on the trans and Amsoil Severe Gear 75-90 in the diff.
I have an 03 Z. The car runs and shifts great.
BTW, I also use Amsoil Signature Series motor oil.
Old Sep 10, 2010 | 09:21 AM
Toque's Avatar
Toque
I am soon to be changing out my diff and tranny fluid.
Did you notice any difference in shifter feel (or anything else) when changing to these above oils ?
Could you send me links to the exact stuff you got ?
Toque
This stuff ? How much ?
Old Sep 10, 2010 | 12:39 PM
dbaker's Avatar
dbaker
Here's the links:
ATD:
https://www.amsoil.com/catalog.aspx?code=ATD1G-EA
SG
https://www.amsoil.com/catalog.aspx?code=SVGQT-EA
Contact and Buy from this guy to get approx 25% off the price you see.
\db2
Carolina
Old Sep 10, 2010 | 01:57 PM
Toque's Avatar
Toque
Originally Posted by dbaker
Here's the links:
ATD:
SG
\db2
Carolina
One you listed is for Auto tranny's. What Amsoil is used for the manual ?
Thanks !
Toque
Old Sep 10, 2010 | 02:07 PM
TS Motorsport's Avatar
TS Motorsport
I use amsoil in the trans, gear and clutch. I use Motul 660 for brake and german castrol for engine oil. This combination has proved best over others for me. One thing I know is that there isn't one company that is best in every category. Good luck!
Old Sep 10, 2010 | 06:15 PM
dbaker's Avatar
dbaker
Thanks !
Toque
It's the same ATD........the Z's manual trans uses auto fluid.
Here's the Amsoil link....
\db2
Carolina
Old Sep 10, 2010 | 06:43 PM
Toque's Avatar
Toque
\db2
Carolina
Cool. I never knew that. Thanks !
Toque
To Tranmission Fluid and Rear Diff Fluid
Old Sep 10, 2010 | 10:43 PM
MTPZ06's Avatar
MTPZ06
Toque
The factory fill is Dextron.
I'm running RP in the trans and diff, but my car is not a DD...so when it sits for a week the shifts are real clunky for the first 10 minutes or so of driving. Thinking of trying Amsoil on my next fluid change.
Old Sep 11, 2010 | 12:12 AM
bud miller's Avatar
bud miller
GM fluids..was fine in my 01 with 65k miles..and a friend 06Z..has got a 110k on his ..factory stock...
Old Sep 11, 2010 | 04:36 AM
SCM_Crash's Avatar
SCM_Crash
Toque
The shifts felt much better. The shifter went into gates much easier.
The below links are the correct links.
Here's the links:
ATD:
SG
\db2
Carolina
