Trunk
Old Sep 9, 2010 | 08:48 PM
Greenlight88's Avatar
Greenlight88
Default Trunk
The trunk is difficult to open. the latch releases just fine, but the trunk does not pop up. I end up needing to pry it open. How do you adjust it so the trunk will pop up when you release the latch?
Old Sep 9, 2010 | 09:02 PM
rdwiv's Avatar
rdwiv
Common problem. Solutions range from free to replacing the struts. I reccommed you use Search and see what works for you. GL
Old Sep 9, 2010 | 09:28 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Get the trunk popper...do a search on here its great
vafirevet's Avatar
vafirevet
I got the C5 Corvette Trunk Popper to fix the problem: http://store.corvettemuseum.com/detail.aspx?ID=2879
It works for $22.
Old Sep 9, 2010 | 09:47 PM
dougbfresh's Avatar
dougbfresh
Just oil the strut rods and hinges, works GREAT and takes all of 2 minutes-best of all, it only cost $0.02 worth of OIL!
Old Sep 9, 2010 | 09:57 PM
O4-/-C5's Avatar
O4-/-C5
Thats what I did.
Old Sep 9, 2010 | 10:25 PM
JanMan99's Avatar
JanMan99
After you hit the trunk opener & the lid opens just a little....make sure both windows are in the up position...open & shut a door and see if it pops up more....it should. That's what I do with my FRC. Good luck
Old Sep 9, 2010 | 11:09 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
The trunk poper is the way to go.
Old Sep 9, 2010 | 11:38 PM
Greenlight88
Who woulda thought? A little lithium grease and the trunk lid is popping up just fine. I will take a look at the "popper" that was mentioned. curious what it is, but grease seems to have solved my issue. Thanks for suggestion....
Old Sep 9, 2010 | 11:43 PM
KorbenDallas's Avatar
KorbenDallas
At $22 for the popper, think of it more as a donation to the museum
Old Sep 9, 2010 | 11:58 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Is "lithium" grease automotive specific grease? I was thinking about greasing both my trunk and hood hinges, however I want to use some good stuff.
Old Sep 10, 2010 | 12:40 AM
striper's Avatar
striper
Just try spraying some WD-40 into the trunk latch mechanism. That worked for me!
Old Sep 10, 2010 | 12:57 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
The popper is a spring and a cap. I went to Orchard Supply and bought two springs 1-3/4" long with a 1/2" diameter and kinda threaded them over the polished part of each of the trunk struts. The trunk now pops up enough to easily get my fingers underneath.
My fix was a couple bucks.
Old Sep 10, 2010 | 10:00 AM
kennya35's Avatar
kennya35
Mine sticks once in awhile as well. All I do is hit the button again and it pops the rest of the way up!
Old Sep 10, 2010 | 10:08 AM
khafe458's Avatar
khafe458
Thats what I do on my FRC as well
Old Sep 10, 2010 | 12:06 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Trunk Popper is what I've got on my FRC. I've got carpet on the trunk lid whichs makes it a little heavy for the stock struts.
Old Sep 10, 2010 | 06:41 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default trunk
I tried 2 very short squirts of WD-40, into the latch mech. and now it pops up about an inchProblem solved for $0 Thanks to all
To Trunk
Old Sep 10, 2010 | 07:42 PM
gtzy's Avatar
gtzy
I had this condition and considered installing an assist spring. I decided to check out why it was not fully popping up.
There is a spring contained in the latch which provides a fair amount of force against the striker which is why the lid needs a decent amount of force to close and latch.
I figured that since there seemed to be enough force from the latch spring to pop it up that there had to be resistance elsewhere [the hinges].
There are multiple pivot points on the hinges. I used a precision oiler to lubricate all the pivot points and then worked the lid/hinges opening and closing to work the lubricate in.
My lid now opens about an inch as it should.
You could lubricate the pivot points on both hinges to restore the engineered function of the lid and latch mechanism that has internal spring to push up the lid. If you enjoy buying things for your car then get the add on device.
GM included a trunk popper which is an internal spring contained within the latch.
The service manual specifies Lubricating all body door hinges and latches including the rear lift hatch[trunk] at least once a year.
For adding pop up gadgets to take the place of vehicle maintenance including lubricating moving parts, there's MASTERCARD
Maintaining your vehicle to operate the way the manufacturer designed it:PRICELESS
Old Sep 10, 2010 | 08:08 PM
tomringo's Avatar
tomringo
Default Trunk
Where did you get the little applicator shown in the pic's?
Old Sep 10, 2010 | 08:44 PM
gtzy's Avatar
gtzy
Sorry, don't recall as I got it several yrs ago
