replacing a fuse
Old Sep 10, 2010 | 01:26 AM
StevieB's Avatar
StevieB
Default replacing a fuse
I ran this same topic in C5 tech. I need to hit the road within the next few days and would appreciate any input;
I can't seem to find any info as far as replacing a fuse. I have the passenger foot well open to the fuse that may have blown for the cruise control considering that it doesn't work. I want to check to see if my cruise control fuse is blown. They are so small I can't get my fingers in there. Is there a special tool for removing them? I don't want to just force it out with some needle nose pliers and risk breaking the prongs.
Thanks in advance.
Steve
Old Sep 10, 2010 | 01:36 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Use the pliers or a small screwdriver works to pry it up and out. You shouldn't break the fuse and/or the prongs. I know they make a special tool for larger fuses, but not sure about small ones. You could also check the fuse using a voltmeter. Good luck!
Old Sep 10, 2010 | 01:40 AM
Trios's Avatar
Trios
They make a tool, usually comes in a package of mini-fuses that you can buy at the auto parts store. Don't worry about hurting it with needle nose pliers; you'll be fine.
You can also get a tester from said auto parts store that will test the fuse while it's still in the fuse box. It has two little prongs that stick into the holes in the top of the fuse to determine if its blown. Little guy is worth its weight in gold IMO.
Old Sep 10, 2010 | 01:53 AM
StevieB's Avatar
StevieB
That sounds like something that would save a lot of work.
C5 tech came up with this within 1 minute, check it out;
should be a fuse tool along with spare fuses in the fuse box under the hood next to the battery.
Originally Posted by StevieB
Yep, there it is. I would have never figured that out. The manual said nothing about it that I could find.
Thanks, I dono how you guys know this detailed stuff, but thanks a bunch!
Old Sep 10, 2010 | 02:05 AM
StevieB's Avatar
StevieB
Anyway, thanks for the replys, thanks a lot.
If i could help somebody figure somrthing out I would. Obviously I'm not the most tech guy around
Old Sep 10, 2010 | 06:48 AM
JerG's Avatar
JerG
I know exactly the fuse you're talking about, it's almost impossible to get out. If you look in the fuse box near the battery, you might find a grey fuse puller. You can try that, mine
was kind of old and worn and didn't work so I had to go to Autozone and got a new fuse
puller (yellow) which fit tighter around the fuse but still would not come out. I finally put
the fuse puller around the fuse and used a small plier around the fuse puller to get it out.
Good luck.
Old Sep 11, 2010 | 09:44 PM
j84buick's Avatar
j84buick
Old Sep 11, 2010 | 09:49 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
That little tool is pretty hard to use. I like needle nose pliers better.
Old Sep 11, 2010 | 11:38 PM
az57chevy's Avatar
az57chevy
You can also use a voltmeter to test the fuse
Old Sep 12, 2010 | 12:03 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
You'll figure it out in time. Soon, you'll be the guy providing answers to new folks.
Best of luck.
Old Sep 12, 2010 | 12:32 AM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
I use plastic hemostats for delicate, close quarters things at work...recently used the " special fuse tool "..located inside the fuse panel door...in my F150..worked well...
To replacing a fuse
