Mine is a 2000 coupe with 90000 miles. It had stock shocks. Surprisingly the old shocks still had quite a bit of resistance.
I started by trying to use a coat hanger to keep the shock compressed to remove it - all that did was waste time. I didn't have any good tye wraps so I used some bailing wire - it worked great.
You don't have to remove anything other than the wheels to replace the shocks. There was plenty of room to get them out.
Glad to hear the improvement! My vette has around 116k so this has got me wondering what Im missing out on!
I was all about coilovers but hearing that they're overkill for the street has got me to thinking of a secondary choice.
My question for you is, Why Z06 shocks? rather than Bilstein or QA1's or just any others?
I'm guessing his decision was based on price...for around $240 they're a good buy. I'm lowered on stock bolts, and I've seen mixed reviews on these shocks when lowered. I'll be going with the Pfadt inverted shocks to get a little more travel over the stockers.
Thats honestly my only thought too, is just a matter of price.
Inverted shocks you say?
Care to school me on a lil info on those?
I assume those are relatively the same as adjustable shocks?
They are inverted to reduce unsprung mass (weight)...the same reason GM engineers worked on making the C5Z rims as light as possible. They are adjustable and offer slightly more travel on lowered vehicles...but most importantly, that adjustability can assist with preventing the car to bottom out. They're pricey as far as shocks go...around the same as Koni FSD's, but much cheaper than coilovers.
So by Z shocks are you referring to C5Z or C6Z? I just learned my buddy has C6Z shocks in his coupe, his ride feel a lot stiffer and stronger where as my Vert is soft and floats. I know his ride has more rigidity because of it being a coupe.
I did the c6 Z06 exchange about a month ago. I also did the Z-51 sway bar upgrade. The car is now really flat cornering and there is a distinctive increase in road feel with the shocks. My 2000 has about 80,000 miles on it so a change in shocks is justified (or so I told the wife). The entire package was around $500 when I include a few non essentials. I highly recommend a shock removal tool you can get at OReilly's autoparts. I forget the neame brand, but it made removing the front shocks a snap. I used the coat hanger method to hold the shocks compressed. To remove, place car on jack stands, remove wheel, place jack under a arm and compress shock using jack, tie off compressed shock using wire or tie wrap and it'll come out fairly easily.
so - what do stock shocks feel like? I bought the car with z06 shocks already in place. I notice that you can really feel the road with them. If you go over a pebble, you know it Even in my vert, it feels very stiff. Also, cornering, you don't feel like tipping (not sure if that has anything to do with the shocks or not.)
The sway bars are what keeps the car level around corners.
The stock bar is about the diameter of your thumb. Z-51's are consideralbly bigger diameter. Early C-5's also have rubber lnks on the sway bars. they look metal, but ain't.
