well tonight I installed new valley cover. I took it for a good run down the highway to clear out some of the oil (I found a puddle in the throttle body, and when I removed the intake manifold, I found oil near the intake ports.) probably explains why it only idled rough for the first 10 seconds in the morning. I will post the outcome tomorrow after a cold start.
Well i just did a cold start up (ambient temp is 15 (60 degrees F))
The issue is 99% no longer there. Barely a hint. I still intend to change out the fuel filter this weekend.
There was alot of oil last night in various places when i had removed the valley cover. I continue to run the pcv as there didnt seem any noticible difference when i blew into the tube (2.5mm orfice) - however there was huge difference not using pcv valve - for the worse
