Help with Vett!!
Old Sep 14, 2010 | 04:07 PM
ChoppaSam's Avatar
ChoppaSam
Cruising
Default Help with Vett!!
Hey ya'll....i recently purchased my first corvette its a 98 c5 pretty much stock, the previouse owner didnt drive the car and had it sitting so i basically recued it off its hands and iam trying to get everything fixed but dont really know too much about vetts but iam a little mechanically inclined....ok so iam trying to fix the check engine light the code it throws is p0113 which is IAT high output but im not sure where the air temperature sensor is located...is it the one right before the throtle body with 2 wires on the side of the plastic intake runner??...and my other question is does anyone have a DIY link on how to remove an a/c compressor??...i searched for it on the forum but the thread i found has a link that doesnt open..... Your help will be GREATLY APPRECIATED!! iam trying to get this car back on its feet riding perfect.....thannks
Old Sep 14, 2010 | 04:18 PM
dougbfresh's Avatar
dougbfresh
Do a search, there is a good link on the AC R&R.
I found it:
http://forums.corvetteforum.com/c5-t...-write-up.html
Search is your friend-always use ADVANCED SEARCH
Old Sep 15, 2010 | 02:42 AM
ChoppaSam's Avatar
ChoppaSam
Cruising
for some reason when i click the "HERE" it doesnt show up....and another thing my oil pressure read 130psi on the HUD and 80 on the gauge cluster what could be the cause of such a high reading??? help greatly appreciated
Old Sep 15, 2010 | 02:57 AM
DeeGee's Avatar
DeeGee
That link to the AC Compressor change is working for me and looks good
The reason for the high oil pressure reading is that the oil pressure sensor has failed and it's very common. You can either change the sensor which is a fairly involved process or you can relocate the sensor. Some members have used a short cut by cutting a section from the cowl which allows easy access.
I'll try to find some links for you.
EDIT:
What you need is in the DIY sticky in C5 Tech:
http://forums.corvetteforum.com/c5-t...iy-thread.html
Post # 62 OPS Relocation
Post # 67 AC Compressor replacement
Post # 79 Oil pressure sensor replacement without cutting or intake removal
To Help with Vett!!
