SC vs NA,It seems from what I read on the forum that a NA 550rwhp run about the same 1/4 mile times as a SC 650 rwhp.I'm looking to Mod the Z and trying to decide which way to go.I know elevation,heat are factors.What else is there to factor?
Ask in the FI section. I'd think the type of FI would make a difference, as well as the way it's set up. If you're talking about 1/4 mile performance, or road course,etc. would all be factors. Roots type SC versus centri, or turbocharging all make a difference on how the power gets to the ground. If your criteria is strictly racing, then you need answers from racers, which I'm not. Good luck.
FYI, you will not get ANYwhere near 550whp NA out of an ls6, some have been lucky to get 500, but driveability severely suffers. To get ~550whp na, you would have to go with a stroked ls3 or ls7, and then you are in 15k range for power not to mention drivetrain, clutch, etc to support that power. Many vendors on here are doing superchargers installed for ~6500 and seeing 600whp all day. Of course tho, you still have the drivetrain and clutch issues.
I would have to disagree with you. I'm at 470RWHP on a Mustang Dyno and a DynoJet with a CAM, Unported FAST 92, and LS2 Intake. No head work at all.
Ported Heads, Ported Fast Intake, and electric water pump and think it can be done. I have no drive-ability issues what so ever. 2002 Z06.
Up to 600 rwhp I'd stay NA if it's within your budget. If you want a little more you can spray it, but if you want much over 800rwhp you need to look at FI.
the reason is because you're comparing peak numbers and not avg power, which is what wins...IATs will also climb faster with FI and unless countered you're not making the same power after a couple gears as you did on the dyno in one gear
Sorry, but the dybno is really really really off.
No way that a stock heads cam LS2 Intake Fast 92 LS6 is putting 470rwhp down - perhaps the car has a very aggresive ehad porting job you are not aware of.
I don't believe the stock LS6 head will not flow enough to deliver that power.
There is a reason us early C5Z adopters that where seeking decent NA hp/torque went with 402, 422, 427 and 440ci. You need the displacement, the heads and the exhausts and 100mm throttle bodies to flow enough to exploit the cam needed to pull that kind of power.
All the 450+rwhp Ls6's have extreme cams and headwork done to support those numbers, unless LS6's behave differently in 2010 to the way they did in 2001, 2002 and 2003.
For simple 1/4 mile work, I would go F/I all the way. Cheaper, less driveline shock and most likely using race gas at the track anyway. If you are road-racing, N/A may be better suited to your needs and you can always spray a little on top for special occassions.
I think a well-built 402/408 could do 550rwhp for well under 15K and would also handle a 150-200shot if needed. I've actually discussed this with a couple vendors because it's something I am looking at doing and they were both confident this plan is do-able.
You will eventually build a forged engine for the boost anyways, so that makes it more of an application decision...
RC, I haven't seen you post in quite a while. Good to see you here again.
Yeah - my car has been down for almost 18 months now with some electric gremlin, so I figure by joining in the chitchat I will get up the motivaiton to try chase donw the issue and get the beast up and running again
