Oil Consumption
Old Nov 17, 2010 | 09:48 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
So i guess its really nothing to worry about , i myself am a quart low, thanks good info for sure
Old Nov 17, 2010 | 06:32 PM
Jet-Jock's Avatar
Jet-Jock
Just to clarify:
1999 - 2002: Service Bulletin: Higher Than Expected Oil Consumption
Subject: Higher Than Expected Oil Consumption (Replace Rings and Engine Valley Cover) Source: Chevrolet Dealer Technical Service Bulletin Number: 01-06-01-023A
Models: 1999-2001 Chevrolet Camaro, 1999-2002 Chevrolet Corvette, 1999-2001 Pontiac Firebird, with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
This bulletin is being revised to add model years for the Corvette, information on the LS6 engine and parts information. Please discard Corporate Bulletin Number 01-06-01-023 (Section 6 - Engine).
Condition
Some owners may comment on higher than expected oil consumption. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
On the LS6 engine only, the technician may find oil behind the engine throttle plate and in the intake manifold.
Cause
The cause for this condition may be an interaction between the piston rings and the cylinder bore in vehicles that are operated at higher RPMs -- typically manual transmission vehicles driven in a manner where the engine is frequently or consistently operating at greater than 3200 RPM.
On the LS6 engine only, the engine has a unique aluminum valley cover that has composite oil separating baffles and PCV plumbing incorporated. In some cases, the PCV baffle may not be properly sealed to the valley cover, causing oil to enter the PCV system.
Correction
On the LS6 engine only, replace the engine valley cover if oil is found behind the throttle body or in the intake manifold before replacing the piston ring. Refer to Engine Valley Cover Replacement in the Engine Mechanical - 5.7L subsection of the Corvette Service Manual.
A new set of piston rings is currently available through GMSPO. The new rings are part of a complete piston ring kit. Install only the number 2 compression ring and the oil expander ring from the piston ring kit. All other rings in the piston ring kit should be discarded. The original number 1 compression ring and the oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
Important Do not dress or hone the cylinder bore. Nothing should be done to change the bore finish for this condition. Changing the bore finish may aggravate the condition.
Refer to the Unit Repair Manual for appropriate ring removal and replacement procedure.
The number 1 compression ring and the upper and lower oil expander rails are re-used because they are already broken in for the bore that they are in. The new number 2 compression ring is made with a very sharp edge that will break in quickly.
Changing only the piston rings noted, with no change in driving style, should change oil consumption to an acceptable level. Changes in driving style that reduce the amount of time spent at higher RPMs will also positively affect oil consumption.
In addition to the standard size piston ring kit listed below, a 0.25 mm oversized piston ring kit is available. The oversized piston ring kit should only be used in those rare instances where the cylinder bore size has been machined larger to accommodate the 0.25 mm oversized piston rings.
Seems like people like to hate on 2001 models, well it affects 1999-2002 models. Your's may have it or it may not.
Old Nov 17, 2010 | 07:16 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Originally Posted by Thunder66
I have a 2001 LS1 that I bought with about 27000 miles on it. It seems to have used about a half quart of oil in 3000 miles or so ( I do drive the crap out of it now and then )... anybody have a similar experience?
I use about a quart about every 5-6K miles and that's when it's time to do an oil change. I have an '01 with 64,xxx miles. I don't consider that excessive.
Old Nov 17, 2010 | 08:00 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
What is wrong with that?
Old Nov 17, 2010 | 10:31 PM
The '00 I had was using a quart of oil every 1200 miles when it had about 11K miles on it. Took it to the dealer and they replaced the #2 rings under warranty. Never used any oil after that.
Old Nov 17, 2010 | 11:07 PM
wcdaniel's Avatar
wcdaniel
Originally Posted by joe_121212
I have the same issue in my 01. Burns more oil the higher you keep the RPMS's.
Dude, IMHO, you gots two choices, shift or put more oil in it !!!!
