Codes - ? they are
Old Sep 17, 2010 | 11:51 AM
jjh3349's Avatar
jjh3349
Default Codes - ? they are
1998 Automatic. (Previous threads on BCM 9/10 and CLB or ? 9/14). These are the codes that came in on the DIC.
C1255 (EBTCM Internal Malfunction)
B2264 (Vertical Position Sensor Circuit)
U1064 (Lost Communication with BCM)
Can anyone explain the above to me ? My Steering does NOT lock, but the fuel shuts off as soon as I give it the gas. Service Column Lock message with Pull Key 10 Second message also appears.
Recall previously done with removal of locking plate at local dealer 2 years ago.
On a hunch someone suggested that the BCM was bad, I don't know. Need help, car is now parked.
Old Sep 17, 2010 | 02:35 PM
Jistari's Avatar
Jistari
Take a look at this post and page down to 87vette7's response.
http://forums.corvetteforum.com/c5-g...f-my-rope.html
Dont confuse the CLB with any of the GM "solutions", even when the K harness or any other dealer fix has been done, you can still have problems. CLB = no problems.
And you didnt put the suffixes on the codes above (H if it was history or C if it is a current condition). Id address the CLB first and clear them and see what comes back.
Good luck
