Front turn signal bulb change
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Are you saying you can change the bulb from the front of the car? Taking off the clear plastic thingy? Because I have broken glass sitting in mine from where I had a bad case of David Banner the other day trying to Trying to reach up into and all around inside that thing was out of question. I just slapped in the new bulb and got back to watching football.
Thanks everybody
Thanks everybody
I always go through the top... My hands are too big to go through the brake duct hole comfortably (although I have done it) and going in through the top is very easy. It also gives you a ton of room to work...
Ten minute job for both sides...
Rep for this thread. I have had my car 13 years and never had to change the front turn lamps. There are 1-2 too many steps in this process but what can you do. I went through bottom access panel and was able to see what I was doing a little better than coming in from top. Thanks!
