Lights dim
Old Sep 18, 2010 | 07:46 PM
blkvette85's Avatar
blkvette85
Default Lights dim
A friend has a 1999. When the headlights are on and turn signals are used the headlights will dim for a second. Is this normal?
Old Sep 18, 2010 | 08:02 PM
joehotwrench's Avatar
joehotwrench
4th Gear
You know for years now my 2000 after driving for about 12 min's at night the headlamps dim only for a split second. I've checked everything and can find nothing wrong. I thought maybe it was the same bump in the road on my way home every night or maybe the first cycle of the cooling fans. I've never had my battery go down and she is always charged and ready to go. But I really dont think this is a normal condition. any help will be great.
Old Sep 19, 2010 | 03:33 PM
toddk's Avatar
toddk
The manual trans cars have an "air pump" by the driver's headlight that runs for a few minutes after startup to warm the cats up. I visibly see the voltage on the DIC drop (along with headlights dip) for about a second periodically for a few minutes.
After its warmed up, headlights on, the turn signals have virtually no effect on voltage for me. If you place a heavy load (have your fan on high, rear window defroster) does it get more pronounced? What does the DIC voltage (or a real VM on the battery) when the signals are applied?
Todd
Old Sep 19, 2010 | 06:37 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Todd
Send Forum Member Bill (Electrical Guru) Curlee a PM. I'll be he can affirm or provide an answer.,
Old Sep 19, 2010 | 07:29 PM
JerG's Avatar
JerG
I would double check the battery, make sure the terminals are tight to spec.
Jerry
To Lights dim
