DIC CODE -please help
Old Sep 25, 2010 | 01:03 AM
tony123's Avatar
tony123
Default DIC CODE -please help
Hi guys, I have this issue with my "Magna Steer Circuit Malfunction ",
code is 28TCS C1241... don't know what to do.
PLEASE HELP
thanks Tony
Old Sep 25, 2010 | 02:02 AM
DeeGee's Avatar
DeeGee
Here's the test procedure. Without a test set and avoiding changing boxes on spec, looks like the only thing you can do at this stage is check connections and grounds
Document ID# 650990
2002 Chevrolet Corvette
DTC C1241
Circuit Description
The variable effort steering (VES) system uses the electronic brake control module (EBCM) to control current to a bi-directional electromagnetic rotary actuator. The EBCM commands current from negative 2 amps to positive 3 amps to the actuator. At low speeds, a negative current is commanded, which assists steering. At medium speeds, no current is commanded and steering is assisted by hydraulics only. At high speeds, a positive current is commanded, which creates steering resistance.
Conditions for running the DTC
* Ignition voltage between 10.5 and 17 volts
* Off state test - Initial ignition ON, no engine rpm or vehicle speed present.
* On state test - If off state test passes, engine rpm and vehicle speed present.
Conditions for Setting the DTC
An open, short to ground, or short to voltage in the VES actuator or the circuits to the actuator.
Action Taken When the DTC Sets
* A DTC C1241 is stored in memory.
* The DIC may display the SERVICE STEERING SYS warning message.
* The VES system is disabled.
Conditions for Clearing the DTC
* A current DTC will clear when malfunction is no longer present.
* A history DTC will clear after 100 consecutive ignition cycles with no malfunction present.
* Using the scan tool.
Diagnostic Aids
The vehicle needs to be driven to view full commanded and feedback current ranges on the scan tool.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2.
Tests if the Commanded and Feedback Current parameters are at the specified value in there active state.
3.
Tests if the resistance of the VES actuator is in the specified range.
7.
Tests the high effort control circuit for an open or short to voltage.
8.
Tests the low effort control circuit for a short to ground.
10.
Tests for poor connections at the VES actuator harness connector.
13.
Perform the setup procedure after EBCM replacement.
Step
Action
Value(s)
Yes
No
Schematic Reference: Steering Controls Schematics
Connector End View Reference: Steering Controls Connector End Views
1
Did you perform the Variable Effort Steering Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Variable Effort Steering
2
1. Install a scan tool.
2. Start the engine.
3. With the scan tool, observe the Magna Steer Commanded Current and the Magna Steer Feedback Current Data parameters in the Magna Steer data list.
Does the scan tool indicate that the Magna Steer Commanded and Magna Steer Feedback Current parameters are within .05 amps of each other and within specified range?
-1.84 to -1.99 A
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 3
3
1. Turn OFF the ignition.
2. Disconnect the VES actuator harness connector.
3. Measure the resistance of the VES actuator.
Does the resistance measure within the specified range?
1.6-3.1 ohms
Go to Step 4
Go to Step 10
4
Test the VES actuator and actuator harness for a short to ground. Refer to Testing for Short to Ground and to Wiring Repairs in Wiring Systems.
Was a short to ground located?
Go to Step 5
Go to Step 6
5
Visually inspect the actuator harness for any cut, chaffed or damaged wires.
Did you find and correct the condition?
Go to Step 14
Go to Step 12
6
Test the high effort control circuit of the VES actuator for a short to ground. Refer to Testing for Short to Ground and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 7
7
Test the high effort control circuit of the VES actuator for an open or short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 8
8
Test the low effort control circuit of the VES actuator for a short to ground. Refer to Testing for Short to Ground and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 9
9
Test the low effort control circuit of the VES actuator for an open or short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 11
10
Inspect for poor connections at the harness connector of the VES actuator. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
11
Inspect for poor connections at the harness connector of the EBCM. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
12
Replace the VES actuator. Refer to Power Steering Gear Replacement in Power Steering System.
Did you complete the repair?
Go to Step 14
13
Important
Perform the setup procedure for the EBCM. An unprogrammed EBCM will result in the following conditions:
* Inoperative, or poorly functioning DRP/ABS/TCS/VSES/VES/TPM system, if equipped.
* Set DTC C1248
* Set DTC C1255
Replace the EBCM. Refer to Electronic Brake Control Module (EBCM) Replacement in Antilock Brake System.
Go to Step 14
14
1. Use the scan tool in order to clear the DTCs.
2. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Old Sep 25, 2010 | 01:53 PM
tony123's Avatar
tony123
ok, thanks ....but is there any other, shorter way to figure out how to resolve that issue using the code because i don't understand half of these things like which actuator and where it is. again, is there any other (in english) way on how to resolve this issue? maybe i just need to replace that actuator but i dont know where it is
thanks again
Old Sep 25, 2010 | 02:15 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
The steps Dee Gee gave are how to correctly diagnose the problem.
It might also help if you provided the year of the car.
Looks like you skipped this sentence "Without a test set and avoiding changing boxes on spec, looks like the only thing you can do at this stage is check connections and grounds"
Check the connections and grounds.
After that your choices are:
  1. Take it to the dealer or dedicated Corvette shop
  2. Throw parts at it until the error message goes away
If you want to do the work yourself the best bet is to pick up a set of factory service manuals.
Old Sep 25, 2010 | 05:23 PM
tony123's Avatar
tony123
ok I checked the ground and it is ok.. you said to check the connections but where are those connections and on what
I just know that this is connecting with the steering wheel but i dont know where those parts that i need to look for are and what parts i need to be looking for (under the car, inside the cabin, under the steering wheel......etc.) how does it look. I will take apart the entire corvette just tell me where the freaken parts are lol.
thanks for helping me out i hope im not bothering you guys too much lol
Old Sep 25, 2010 | 06:34 PM
Blue 92's Avatar
Blue 92
More than 1 ground on the car. - see attachments
VES actuator location - see attachments
File Type: pdf
Old Sep 25, 2010 | 08:56 PM
tony123's Avatar
tony123
ok I mist 1-4-5 .... thanks
To DIC CODE -please help
