[Z06] 17s all around
Sep 25, 2010 | 11:18 AM
17s all around
How many have put 17s all around on their car? In the market for some new wheels and trying to figure if I want to keep with the staggered wheels or go with same size on all four corners. Defiantly make rotating tires easier and it seems like there is more selection on the width of the tires.
Thanks,
Brandon
Sep 25, 2010 | 04:08 PM
If you own a Vette, your last concern should be rotating tires.
Sep 25, 2010 | 04:09 PM
If you wanna rotate your tires get a Daily Driver, like a Honda
HAHA just messin with ya, Dont think many vette guys worry about tire rotation.
Sep 25, 2010 | 04:20 PM
YES some guys put 17" all around. But not to rotate tires. more for light wt and accelerations.
Sep 25, 2010 | 05:56 PM
Quote:
Originally Posted by
AU N EGL
has anyone heard of anyone installing the front 17" Z speedlines on the rear ? wonder if that works.
Sep 25, 2010 | 08:18 PM
C5ZEE06
I wouldn't see why there'd be an issue with this. The rear brakes are pretty small so there wouldn't be a clearance issue at all and they're not as wide as the 18's so they should fit with ease.
Sep 25, 2010 | 08:34 PM
Sep 25, 2010 | 09:30 PM
I'm not too concerned about rotating tires just saying it is a benefit if it was needed. Curious to why 18's would be better?
Sep 25, 2010 | 09:42 PM
biggums46
So you can fit brakes in them. assuming this a performance based question
Sep 26, 2010 | 03:01 AM
biggums46
Wider tires and the shorter sidewall will flex less. Why would you want to put less rubber on the ground?
Sep 26, 2010 | 03:03 AM
17's at all corners just wouldn't seem right. May have an issue with the traction control system.
I'm running 18's at all corners but the rear are 12" and the fronts are 10.5".
If a vette owner is concerned with tire rotation they should get a mini van.
Sep 26, 2010 | 07:38 AM
no problems with 17s. Most guys run 17x11 rims with 17x315/35 on all four corners.
18s may be a better choice. I have been running 18s since fall of 03
Sep 26, 2010 | 01:19 PM
speedyhawk101
Haha I'll keep the vette
Sep 26, 2010 | 03:31 PM
hahaha ok then you do that
Sep 26, 2010 | 04:30 PM
biggums46
Thanks,
Brandon
On a ZO6, i certainly wouldnt go to a 17 rears. Wouldnt look right, possible traction control issues. 18s all around would be better. Even 18F-19R is possible. And ditto on worrying about tire rotation.
Sep 26, 2010 | 10:44 PM
I'm looking at 18's all around
I'm not interested in rotating advantages. I'm looking at upgrading brake calipers and 18's give more options. I would be interested in purchasing your original 18X10.5" rear wheels if they are argent color.
Sep 26, 2010 | 10:49 PM
Interested in 18's all around.
What make wheel did you use? I want to go to 18's all around.
speedyhawk101
Sep 27, 2010 | 02:15 AM
55ratt
OEM 18x10.5 front , widened OEM rear
Sep 27, 2010 | 08:51 AM
fstws6
18's would be better.
Here is my 18 set up. Fikse Profil 10's . Pics are at stock ride height. Im lowerd on stock bolts now and need to take new pics.
18x9.5 front,265-35-18 PS2's
18x11 rear,295-35-18 PS2's
Sep 29, 2010 | 08:00 PM
FourG63 97GST
You answering for me, or you got the same set up?
But yes you are correct.
55ratt
What he said /\
I did this so I could run C6Z brakes without spending A LOT of money on a light weight set of wheels.
