Oil Life
Old Sep 28, 2010 | 09:52 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default Oil Life
When we got our '03 vert in July - our first and its great!! they had just changed the oil about a week before, when I picked it up it said 99% on the oil life. Am about 200 miles short of 3k now, and the oil life says 75%, getting ready to change in the next couple of weeks for the winter (a very bad thing that happens in the North), but was wondering why it's not closer to 0%.
Old Sep 28, 2010 | 09:55 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
because the way it works is based on a variety of things not just mileage. Some will disagree BUT I say listen to the DIC. However in this case since you are changing it before parking it for the winter I would say go ahead. But then again I live in Florida.
But the old thinking about changing every 3000 miles is just that ...old, outdated. Todays synthetic oils last much longer.
Old Sep 28, 2010 | 09:57 AM
pewter99's Avatar
pewter99
I am sure Evil Twin will be happy to explain to you "WHY" (as he has done so many times before ) the Oil Life Monitor can be trusted and how it works
Old Sep 28, 2010 | 09:58 AM
Edmond's Avatar
Edmond
3000 oil changes are a thing of the distant past. Even conventional oils can protect your engine well for over 4000 miles. The synthetic that comes factory in the Corvette will protect well beyond 4000 miles.
The oil life meter, (OLM) does not gauge the life of the oil by miles. It gauges the life by various factors such as temperature, cycles, etc...
Trust the OLM, it will not steer you wrong. Make sure to use a synthetic and a good filter: Delco, Purolator, etc...
Old Sep 28, 2010 | 10:01 AM
DeeGee's Avatar
DeeGee
E-T who was involved in the design of the C5 will comment on this
The GM oil life monitor is a complex algorithm which checks all the parameters of the engine and gives you a % life remaining based on your useage assuming you use synthetic oil which meets the GM spec
You can safely run it to 0% and many of us have and do.
If you change now you're wasting 3/4 of the oils life. That said, fresh oil before it goes into storage is not a bad idea
Old Sep 28, 2010 | 10:03 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
So do today's Dino Oils.
Old Sep 28, 2010 | 10:05 AM
pewter99's Avatar
pewter99
true but I figured since we were talking C5's that was irrelevant
Old Sep 28, 2010 | 10:16 AM
ztheusa's Avatar
ztheusa
Mostly, people call me irreverent, not irrelevant.
Old Sep 28, 2010 | 10:38 AM
1320b4you's Avatar
1320b4you
Default oil life
I wouldn't let it get under 15% though, as effective as it calculates remaining oil life, certain unmeasurable instances can come into play. I do change mine every 3500 though for piece of mind regardless of what the dic states. Even minimally driven cars should be changed at last once a year in my book regardless of miles driven
Old Sep 28, 2010 | 11:40 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Just a short note on this post...I wont argue or post again..
You can safely take the OLM down to 0 %, there is still a bult in safety factor.. the OLM is so good that we changed the baseline of 10,000 miles in the original program, and after two years of field data we upped the baseline to 15000 miles in 2000.
ON the second note.. where you say at last once a year in my book ".. not only is it in your book, it is in everyones book, just look at your owners manual.. The detergent package found in the oil mixes with the combustibles and after a year these combustibles will change the chemistry. The contaminants will effectively change the PH of the oil turning acidic. Once the procedure starts, be it a few hundred miles or a few thousand miles, the catalyst is in place to turn your oil acidic.. its like mixing a two part epoxy,,, the time interval is about a year. so you want to follow your book ( owners manual ) and change using the OLM or 1 year whichever comes first.. ) Take this information or leave it.
Bill aka ET
Old Sep 28, 2010 | 12:02 PM
jrose7004's Avatar
jrose7004
I go one year or 10,000 miles whichever is first.
Old Sep 28, 2010 | 12:06 PM
Exactly. No need to change the oil every 3K miles anymore. The DIC oil life monitor is pretty accurate and something you can go by. The only exception is if you just don't drive the car enough to get the oil life monitor down close to 0% - I fall into that category. I change my oil just before I put it away for winter and then I'm ready to go until next winter's storage time.
Old Sep 28, 2010 | 01:16 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Bill aka ET
I'll leave it. In my case, I get down to around 70% oil life remaining on the OLM after a year of driving (mostly weekend pleasure driving or weekend trips). At that level the oil is far from being even moderately contaminated or acidic. I am comfortable going up to two years before a complete oil change, and even then the OLM still shows around 35% oil life remaining. I do offset the longer interval between oil changes by changing the filter (which takes no more than 5 minutes to do) after one year, so as to have a fresh new filter on for the second year on the oil.
Old Sep 28, 2010 | 01:54 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Synthetic oil should give you 7500 miles no problem. However I change mine once a year (with filter) because I never get anywhere near 3000 miles in a year let alone 7500. I know, I know, now starts the "drive your car more"...
Old Sep 28, 2010 | 02:20 PM
tomringo's Avatar
tomringo
Thanks guys great info and now I know more about my vette then I did based on your experainces. Again that's one of the things I like about this forum, good info, good things to think about and good company. I'll stay with my plan to change in fall and at mimimum once a year Now you can get on about "need to drive the car more" Thanks
Old Sep 28, 2010 | 02:39 PM
mschamberger's Avatar
mschamberger
Bill aka ET
ET's word is gospel in my book.
Old Sep 28, 2010 | 03:18 PM
Rebel 1's Avatar
Rebel 1
I change oil/filter at 1 Year as the engineers recommend even if only a few thousand miles are driven, as in my case. I would never take a chance going longer, makes no sense at all given the fact that the engine is the Most Expensive part of the car.
6 quarts of Mobil 1 and Delco filter is Cheap Insurance.
To Oil Life
Old Sep 28, 2010 | 04:04 PM
Dominic Toretto's Avatar
Dominic Toretto
I just change the oil when it gets black like everyone else
-Alex
Old Sep 28, 2010 | 05:23 PM
killain's Avatar
killain
Oldtimer
Default Mid-Mid oil changes !
I noly change my Mobil-1 once a year in August, I have the car checked for state safety inspection and have the oil and filter changes. The oil life monitor always says 86% or so, but I only drive the car 2K miles in a year. So the owners manual says 7000 miles or once a year. You can't go wrong following the owners manual, but as mentioned above, since your putting it away for winter, ( I'm going to be doing that in November) I'd go ahead and change it. You can get 7 quarts of Mobil-1 at walmart for $32.00, and the GM dealership charges $28.00 in labor, Cheap to me considering I paid $48K for the car when new.
Old Sep 28, 2010 | 05:25 PM
pewter99's Avatar
pewter99
