Instrument trim panel Removal
Old Sep 29, 2010 | 02:26 PM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
Default Instrument trim panel Removal
I may have over looked it in searching the forum,
BUT i need to replace my radio with a Nav. unit, How do you get to the radio, so i need to remove the Instrument trim panel , to take out the radio, any help with this would be great.
Old Sep 29, 2010 | 03:10 PM
DeeGee's Avatar
DeeGee
Try my post #16 in this thread. Different HU but all you need to know is in there.
http://forums.corvetteforum.com/c5-t...iy-thread.html
Old Sep 29, 2010 | 06:14 PM
00Corvette's Avatar
00Corvette
Super easy.
Open console, pop out two little access panel thingys with a flat head.
remove 2 10 mm nuts
pop out traction control/active handling panel w/ flat head screw driver
remove 2 more 10 mm nuts
disconnect 12V charging jack electrical plug, traction control plug(active handling if you have it) and fuel door release plug
Slide the whole center console toward the rear of the car and remove from the car
Remove your ash tray, remove torx screw behind it plus one more next to the cig lighter, remove little panel next to your ignition switch that has the little "vent" in it, this is your inside air temp sensor. one more torx behind that, remove it.
put the car in low gear if it's an auto, then just pull the panel off
Old Sep 29, 2010 | 06:15 PM
00Corvette's Avatar
00Corvette
read the ultimate DIY thread also..it's a sticky you don't even have to search
To Instrument trim panel Removal
