Will this also work on a regular C5?
Old Oct 1, 2010 | 12:20 PM
patjza80's Avatar
patjza80
Default Will this also work on a regular C5?
Hey guys, my father just bought a 2000 auto C5. Back when I had my 03' Z06, I put this filter on.
http://forums.corvetteforum.com/c5-z...ir-intake.html
Is there any reason why this wouldn't work on a base auto C5? I just want to make sure it wont throw a code and that it will fit.
Thanks in advance.
Old Oct 1, 2010 | 12:56 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
It should work fine.
Old Oct 1, 2010 | 01:46 PM
PostShawn's Avatar
PostShawn
The key here is the years. The 1997-2000 had a slightly different intake then the 2001-2004s. The earlier ones had a air hose that I think goes into the intake tube and not the filter. If you have the filter only that you are giving him I think it's fine. If it's the whole intake kit then there might be a missing air hose hole that's needed on the earlier intake tubes.
Old Oct 1, 2010 | 02:25 PM
patjza80's Avatar
patjza80
I see. Its just the filter. In that case that would save me from having to make a spot to connect the air hose too. Thanks
Old Oct 1, 2010 | 02:42 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
just buy one that is model year appropriate
Old Oct 1, 2010 | 02:49 PM
jrose7004's Avatar
jrose7004
Shouldn't be a problem.
Old Oct 1, 2010 | 03:02 PM
patjza80's Avatar
patjza80
Its a universal filter, not a kit
To Will this also work on a regular C5?
