Subtle Bling
Old Oct 13, 2010 | 08:15 PM
DaBoz's Avatar
DaBoz
Default Subtle Bling
Can you see it?? Chrome covers over that fugly part of the rotor that gets rusty.
Expensive for what they are but it's all in the details!
Old Oct 13, 2010 | 08:57 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice bling
Old Oct 13, 2010 | 08:59 PM
91LSMAN's Avatar
91LSMAN
Looks Good. I love mine.
Old Oct 13, 2010 | 09:59 PM
Looks really good. Sure cleans up that area.
Old Oct 13, 2010 | 11:15 PM
corvettedaddy11's Avatar
corvettedaddy11
I like the set I had !
Old Oct 13, 2010 | 11:27 PM
DaBoz's Avatar
DaBoz
Not so obvious with mine but a must with your open Z06 rims
Old Oct 13, 2010 | 11:34 PM
jrose7004's Avatar
jrose7004
Not bad!
Old Oct 13, 2010 | 11:48 PM
4 KRUSIN's Avatar
4 KRUSIN
For some reason, I can't see the pic. I'm guessing that they are the same covers I bought for mine this year. They are suttle, but I have had some positive feedback about them. I bought the chrome plated aluminum ones so they should always look new. I also think the thin spokes show them off very well.
Old Oct 14, 2010 | 07:22 AM
JerG's Avatar
JerG
Looks nice with your wheels.
Can you put them on easily without removing the calipers on a C5?
Old Oct 14, 2010 | 11:08 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Easy.
You take off the tire, slide the cap over the lugs onto your rotor while it's still on the car and bolt the tire back on. With the tire off it takes all of 3 seconds to slide on.
Old Oct 14, 2010 | 11:16 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
very nice, indeed
Old Oct 14, 2010 | 11:20 AM
rebelheart's Avatar
rebelheart
Sure looks like they would be a chore to keep clean!
Old Oct 14, 2010 | 11:52 AM
ricknyc23's Avatar
ricknyc23
I was thinking of buying the caps in black. glad to see you dont have to remove the calipers!
Old Oct 14, 2010 | 01:49 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Especially with the CCW Classics. But it does look nice.
Old Oct 14, 2010 | 03:28 PM
ssidekickbp's Avatar
ssidekickbp
where can I order these from?
Old Oct 14, 2010 | 04:12 PM
DaBoz's Avatar
DaBoz
You don't have to remove the calipers but you DO have to move them away from the center of the hub.
Process is: Loosen top caliper bracket bolt, remove bottom bracket bolt, swing caliper out a couple inches and THEN they just slip on. The bolts are torqued to 125 lbs and are a PITA to remove. Following some suggestions from members here I finally heated them with a torch for a couple of minutes and then they came off with little effort. (Still needed a breaker bar and a sledge hammer!)
Old Oct 14, 2010 | 04:14 PM
DaBoz's Avatar
DaBoz
http://www.westcoastcorvette.com/p-1...-04-c5z06.aspx
Old Oct 14, 2010 | 04:26 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Excellent choice - I have mine in black
Thanks,matt
To Subtle Bling
