Storing 2001 Corvette
Old Oct 14, 2010 | 10:04 AM
hdboomer's Avatar
hdboomer
Default Storing 2001 Corvette
I will be leaving my car in my garage for 3 months, no one driving it or starting it up. What should I do? Disconnect battery or anything special? Full tank of gas, add stabilize for fuel?
Thanks for info.
Old Oct 14, 2010 | 10:15 AM
vettespur's Avatar
vettespur
Thanks for info.
you got it
remove negative battery cable
change oil beforehand
add stabil and top up fuel
Old Oct 14, 2010 | 10:25 AM
dougbfresh's Avatar
dougbfresh
Mine sits in the garage most of the winter on a battery tender-that's it.
Old Oct 14, 2010 | 10:59 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
If I have a battery tender connected to the battery during winter storage should I also disconnect the negitive battery cable leaving the positive connected? I wasn't planning on disconnecting the battery, but this will be my first winter storage year for the vette. thanks
Old Oct 14, 2010 | 11:45 AM
markKlein's Avatar
markKlein
Leave the battery connected, just hook up a battery tender.
Old Oct 14, 2010 | 11:47 AM
NittanyLionDen's Avatar
NittanyLionDen
I do the same. No problems.
Old Oct 14, 2010 | 11:49 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I suggest if you leave the battery in the vette to hook-up a trickle charger like a Ctek 3300 & leave both cables on...I don't know if you have any mice or other possible trouble makers around you may want to set some traps & use some bounce fabric sheets. You may need to make a list of what you've done so you don't forget to undo them when it's time to wake-up your baby. Good luck!
Old Oct 14, 2010 | 02:17 PM
Jims79's Avatar
Jims79
Originally Posted by vettespur
you got it
w/all of the above except disconnecting the neg battery cable. Leave the battery connected and buy a 2amp tender. And I would add put 30lbs of air in all four tires.
Old Oct 14, 2010 | 02:27 PM
hotwheels57's Avatar
hotwheels57
My battery is maintained with a BATTERY TENDER PLUS for six months of winter. The memory functions are maintained and it's ready to take out on a winter weekend if weather permits.
Old Oct 14, 2010 | 02:46 PM
ChromeC5's Avatar
ChromeC5
Ctek. And if you do have mice issues, also put some steel wool in your exhaust tips to keep them from crawling up in there and making nests.
Old Oct 14, 2010 | 03:06 PM
dougbfresh's Avatar
dougbfresh
Old Oct 14, 2010 | 03:29 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Zacley ! I also try to keep a full tank sometimes with sta-bil. I do take it out during the winter when it is sunny and as dry as possible.
Old Oct 14, 2010 | 03:52 PM
Mr. Jean's Avatar
Mr. Jean
I've used the C-Teck on mine for 3 years and it works fine. I prefer to leave the battery all hooked up and ready to go. You never know when an emergency will happen and you need to move it fast. Think garage/house fire or something similar.
Old Oct 14, 2010 | 04:54 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Cover it, tender it, check tire pressure...mine stays that way for 7 mos...no problems.
Old Oct 14, 2010 | 08:11 PM
SUNNYD 95's Avatar
SUNNYD 95
I do all of the above, I also put a few drier sheets on the floor around the car to keep mice from going under the hood, because if there hungry they love to eat wires we DON'T need that on a vette.
Good kuck
Old Oct 14, 2010 | 09:52 PM
I've got several files that discuss storage of cars - if you'd like a copy, PM me your e-mail address.
To Storing 2001 Corvette
