c5 oil pressure
Old Oct 15, 2010 | 06:35 PM
calivette805's Avatar
calivette805
Default c5 oil pressure
What should our oil pressure be at a stop and wot. Never really paid attention to this gauge
Old Oct 15, 2010 | 06:42 PM
ZZ06's Avatar
ZZ06
well what is your gauge telling you. Thats actually the gauge you should be paying attension to the most. WOT should be 50+psi from a hot idle.
Old Oct 15, 2010 | 06:47 PM
calivette805
At a stop 39 wot mhh like 60ish or more
Old Oct 15, 2010 | 07:01 PM
ZZ06's Avatar
ZZ06
well i said 50+ plus i cant remember what my LS1 pump used to put out in my Camaro. My ZO6 does put out 60+ at WOT and sits around 42-44psi at hot idle. Your pressure is fine. Drive w/o worry
Old Oct 15, 2010 | 09:47 PM
Your pressures are fine. That's about what mine reads.
Old Oct 15, 2010 | 09:52 PM
Aerovette's Avatar
Aerovette
Crap. 20K and I am at 37 idle and about 48 under fairly hard acceleration. WTH?
Old Oct 15, 2010 | 10:16 PM
ZZ06's Avatar
ZZ06
people have different meanings for this.....WOT is exactly what it means! Try it and see.
Old Oct 15, 2010 | 11:53 PM
white22's Avatar
white22
High 20s to around 40 at idle and between 40-50 while accelerating then 50+ at hard acceleration. Your readings are fine. I finally know what mine are after I got my sensor replaced!!! It's nice knowing, although replacing that sensor was tons of fun!
To c5 oil pressure
