withheld corvette!
http://www.hotrod.com/howto/113_0504...ics/index.html
The only other number would be a partial vin which would just be the last few digits of your VIN number. Which is basicly just the build date
Here is a quote directly from the GM 2004 Corvette Restoration Guide page 13.
“The engine ID number will be located on the rear of the LH cylinder head or the front part of the LH oil pan rail.” From the picture it looks like it is on the BLOCK just to the rear of the driver’s side head, either in the horizontal or vertical surface. “The eighth digit of the vehicle identification number (VIN) is the engine code letter, which identifies the engine as a 5.7L V8 (VIN eighth digit: G= RPO code LS1 and S=RPO code LS6.”
The ID number may be a stick-on label, laser etching, or stamping on the block.
The code will also have a VIN derivative or part of the car’s serial number just like the old ones.
Get the number off the block directly as stated in the above replies
Part 541 - Federal Motor Vehicle Theft Prevention Standard (Effective 4-24-86; amended 10-25-95) This standard specifies performance requirements for identifying numbers or symbols to be placed on major parts of certain passenger motor vehicles. The purpose of this standard is to reduce the incidence of motor vehicle thefts by facilitating the tracing and recovery of parts from stolen vehicles. This standard applies to the following:
(a) Passenger motor vehicle parts identified in Section 541.5(a) that are present:
(1) In the passenger motor vehicle lines listed in Appendix A of this part;
(2) Beginning with model year 1997, in passenger motor vehicle lines which NHTSA has finally determined, pursuant to 49 CFR Part 542, to be high theft based on the 1990/91 median theft rate; and
(3) Beginning with model year 1997, in passenger motor vehicle lines listed in Appendix B of this part.
(b) Replacement parts for passenger motor vehicle lines described in Section 541.3(a)(1) and (2), if the part is identified in Section 541.5(a).
I don't know who you have to talk to, but if you can get an inspection done, tell 'customs' (?) that the last 7 digits on the engine will match the vin (if original engine). There will be no paper work for this, anywhere. Right front side of block under head or Left Rear. Mirror and a flash light if needed.
Fill out the paperwork and get your car back.
