Column lock problem
Old Oct 20, 2010 | 08:33 PM
dkrose54's Avatar
dkrose54
Default Column lock problem
HEY GANG , I WOULD LIKE TO THANK EVERY ONE WHO RESPONDED TO MY PROBLEM, ITS FIXED!!!! 500 MILES OF STOP AND START AND NO PROBLEMS, I HAVE NOTICED THAT THE TEMP GOES TO ABOUT 225- 235 IN CITY DRIVING STOP AND GO , AND RUNS AROUND 194 DRIVING OPEN ROAD, IS THIS NORMAL
Old Oct 21, 2010 | 11:33 AM
wamara's Avatar
wamara
Cruise-In II Veteran
With the stock radiator and thermostat, I would say it is normal. Just do the usual checking that there is no debris in front of your radiator, and that your fans turn on with your A/C on. Even without your A/C on, your fans should be kicking on around the 225-230 mark to bring down temps. A bit more work will involve pulling your thermostat and checking its performance, and hosing out your radiator for any debris. If it still bothers you, I believe you can change your fan temp activation setting and put in a lower temp thermostat. Good luck.
Old Oct 21, 2010 | 04:35 PM
dkrose54's Avatar
dkrose54
i thought it was normal after looking at some other posts, my first vette , and just getting to know her, its a little scary to see the temp climb to 225 or 230 at a traffic lite 170 miles from home, but it returns to 194 when i get going. thankyou for the imput.
Old Oct 21, 2010 | 04:39 PM
hotwheels57's Avatar
hotwheels57
Unless your original stock fan settings have been altered...
QUOTE:
"The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph)."
Old Oct 21, 2010 | 04:56 PM
dkrose54's Avatar
dkrose54
thank you very much, never knew their were so many people out there who gave a crap about their fellow vette owners, its a very close nit community
To Column lock problem
