Do what Bill says. Hopefully the reprogramming is all that is needed.
And - since these cars have a draw on the battery while sitting still, not surprised that the Optima ran down. If you don't drive it much, best to keep it hooked to the battery tender.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Matching Transmitter(s) to Your Vehicle
Each remote keyless entry transmitter is coded to prevent another transmitter from unlocking your vehicle. If a transmitter is lost or stolen, a replacement can be purchased through your dealer. Remember to bring any remaining transmitters with you when you go to your dealer. When the dealer matches the replacement transmitter to your vehicle, any remaining transmitters must also be matched. Once your dealer has coded the new transmitter, the lost transmitter will not unlock your vehicle. Each vehicle can have a maximum of three transmitters matched to it. To match transmitters to your vehicle: 1. Turn the ignition key to ON. 2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button. 3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds. 4. When the message FOB TRAINING is displayed, press the RESET button once. The message HOLD LK + UNLK 1ST FOB in the DIC will be displayed. 5. Press and hold the lock and unlock buttons on the first transmitter simultaneously for five seconds. 6. When a transmitter is learned (matched), the DIC will display FOB LEARNED and then prompt you to learn the second transmitter. 7. Repeat Steps 5 and 6 for the third transmitter. 8. Remove the key from the ignition. The programming mode will shut off if any of following has occurred:
You don’t program any transmitters for two minutes.
You take the key out of the ignition. You have programmed three transmitters
So, if I have 2 FOB's (One is new one is old) and I only change the battery in one, do I need to re-program both FOB's OR just the one with the replacement battery ?
Thanks Mr Bill for the detailed procedure. I was doing fine, got the step where it stated FOB Training, then I pressed the RESET --- nothing happens. Did not get the prompt to press lock and unlock ?
There was a beep that let me know that I had pressed the reset, but nothing. Tried to press the buttons anyway .. no luck..
Any suggestions ???
Thought about disconnecting the battery.. possibly restart the computer module ??
My FOBS were NEVER used for the first 12 years. Both DEAD,replaced the batteries from Wallgreens, went through the process to reprogram and all was good! I changed out the dead Red Top to a Yellow Top and FOBS were still programed..
