How to Improve Ride Quality?
I'm looking for suggestions on how to improve the ride quality of my car.
It's a 2003 Z51-equipped Coupe. I'm running stock size non-run-flat Nitto NT555 tires. The suspension is completely stock.
I'm sure many of you'd disagree, but I think the ride's kind of harsh.
I test drove a 2008 C6 Saturday and was impressed with the ride quality even on the stock Goodyear run-flats. The car was admittedly a base suspension car.
I'm looking to improve ride quality, but not lose any cornering ability or, at least, not much.
Thanks.
Thanks.
Reduce unsprung weight
One of my future upgrades will be Bilstein Sport shocks. Based upon what I've read, they should be superior (handling-wise) to the Z51 shocks but I'm not sure if the ride will be better. good coilovers, like LG's may help as well. Another way to improve ride quality is to reduce unsprung weight. However, if you are running the optional polished wheels, you'll probably have to spend quite a bit to get significantly lighter wheels (forged would be necessary).
St. Jude Donor '09, '13, '15
maybe you have this issue.....
http://forums.corvetteforum.com/c5-g...-surprise.html
Never know...might be worth a look-see
Received 19,427 Likes
'20-'21-'22-'23-'24
Take a look at your shocks and make sure they are OK. Could be they need replacement.
C5workinprogress (03-15-2024)
I have a 2001 vert, 6spd, 37,000mi. Will be installing the Koni fsd shocks, but have a choice to make wheel-wise...N73 GM Magnesium wheels or 18/19 chrome aftermarket spyders. How much do I really hurt the cars all around performance by using the heavier aftermarket wheels? Has anyone ever gone as far as to remove them due to weight related issues?
Coilovers. Installed Pfadts on my car and the ride is stiff but not harsh. It becomes a whole different car. I noticed on my old vert the ride was soft but when you hit a bump it was jaring, you don't get that with coils just feels like much more positive road contact.
These not only improved ride quality for me, but made the car over all way more capable of a performance car in every way. No downsides. I'm still giggling every time I go out for a drive.
I know the non-adjustables use Bilstein shocks but am not sure what these use.
