ABS and Active handling
Old Dec 14, 2011 | 11:53 PM
02koolC5's Avatar
02koolC5
Originally Posted by RameezC5
My lights were constantly ON and won't go away. I replcaed my battery and cleaned up everything.
Code: C1214. To fix it I need to get my ABS Module rebuilt. I just havn't found anyone locally and I don't know if I should just ship it. Let me know if anyone had their ABS Module rebuilt. Thanks
http://forums.corvetteforum.com/c5-t...y.html:cheers:
Old Dec 18, 2011 | 05:50 PM
RameezC5's Avatar
RameezC5
8th Gear
The link is not working.
Old Dec 19, 2011 | 08:28 PM
germanc5's Avatar
germanc5
My 99 did that this summer. Tried cleaning the abs sensor connections and battery connections. What worked was driving on to wet grass and slamming on the brakes (activating the abs system). Light hasn't been on since.
Old Jan 6, 2012 | 02:18 PM
BBM's Avatar
BBM
8th Gear
Default Abs, tc & ah
My AH, ABS & TC are on all the time, once in great while, the TC goes off but comes back on after next start. Also the TC switch does not work.
I am getting a code of U0121, lost connection to ABS control module 2, 3, 4, 5, 6 & EBCM
I have checked all my connections and grounds and they all are clean and good.
I tightened the connectors on the SWPS by taking them apart and cleaning and tightening the female connectors, then slightly bent the male ones to make it tighter yet.
Would you have any suggestions?
My car is a twin turbo 07 C6 with 694 RWHP and is very scary with no TC, AH or ABS
Thanks again, Barry
Old Jan 6, 2012 | 02:24 PM
RameezC5's Avatar
RameezC5
8th Gear
I sent my module out to ModuleMaster to get it rebuilt but my code was C1214 once I reinstalled the Module the ABS & TC Lights were off but after driving for only a day they came back on. Once I turn the car off and turn it back on they go away but after driving for like 2-3 miles it comes back on. Very annoying. They are asking me to send them the module back. Modulemaster.com or ABSFixer.com see if they help you out.
Old Jan 6, 2012 | 11:07 PM
02koolC5's Avatar
02koolC5
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Thats a bummer to have to go though all that.
I would send it back to the place that you paid to fix it, but if I had to send it anywhere it would be ABSfixer, just because they have repaired so many.
The thread above is a DIY fix, its how I did mine good luck vette brother
Old Jan 6, 2012 | 11:25 PM
RameezC5's Avatar
RameezC5
8th Gear
Ok so I spent almost 4 hrs to clean up all the things that has to do with ABS no more lights drove it for straight 30 minutes feels good to drive with no lights good luck to others thanks....
Old Mar 15, 2012 | 07:46 PM
myredht's Avatar
myredht
There were no codes but the DIC says low voltage.
Old Apr 10, 2012 | 05:07 PM
myredht's Avatar
myredht
Replaced the battery a few weeks ago so far so good.
