Another Lowering Request
Old Nov 2, 2010 | 11:23 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Another Lowering Request
Ok I need a little help. I have seen many post about lowering and pictures of C5 lowered with larger wheels (18/19 & 19/20). I am planning on doing a few thinks to my '01 over the next week or so and lowering it is one of the items. I would like to see what I can expect with using the stock bolts and stock wheels (17/18). So if anyone has any pictures of this situation I would like to see them.
Old Nov 2, 2010 | 12:08 PM
jrose7004's Avatar
jrose7004
Here's mine lowered all the way on stock bolts with stock size i-Forged Swifts.
Old Nov 2, 2010 | 12:55 PM
--Z06--'s Avatar
--Z06--
That about sums it up. Get an alignment a couple weeks after she settles down.
Old Nov 2, 2010 | 01:00 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
This is my C5 ( I sold it a couple years ago) It was lowered on stock bolts. It has 18" wheels here on all fours BUT the tires equal OEM Z06 sizes (Outside Diameter)
Once lowered as you can well imagine, you should have a 4 wheel alignment done. No need to wait, it will settle down after driving it ONCE. One application of the brakes, one launch and it's settled.
Old Nov 2, 2010 | 01:09 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Thanks for your picture from the front. I also have the ACI splitter and that is my main concern. Looks ok to me. I realize I need to watch for speed bumps as well as pulling in and out od driveways.
Old Nov 2, 2010 | 03:10 PM
MG RED 99's Avatar
MG RED 99
Some more pics for you. Lowered on stock bolts front and back. Stock size wheels. Also have the ACI splitter. if you have the option to leave the front a little higher and lower the rear as far as it will go. This will give the front a little more clearance. If you notice on mine the rear is a little higher than the fornt. I need to reverse this to get a little more clearance. I don't have any problems getting in and out of steep inclines as long as I can take it at a sharp angle, but the front is low.
Front
Rear
Old Nov 2, 2010 | 03:36 PM
Munky's Avatar
Munky
18/19(sorry), and I used a lowering kit, but did not max it out. This should be very close to what full low on stock bolts will look like.
Old Nov 2, 2010 | 03:39 PM
Munky's Avatar
Munky
It is important to keep the natural rake of your car back to front for aero purposes. Off the top of my head I think i sit 26.5 back, and 26 front from ground to fender.
Old Nov 2, 2010 | 06:32 PM
SJC5's Avatar
SJC5
Here's mine lowered on stock bolts, cut 1/2 the front bushings and standing on 17/18 Cray Scorpions.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
To Another Lowering Request
