[Z06] ?? resurface flywheel??
Old Nov 3, 2010 | 02:00 PM
MStrahan's Avatar
MStrahan
Default ?? resurface flywheel??
Hey guys and gals, I need your opinion on resurfacing my flywheel.
My 04Z has 70k on the clock and it looks like I'm heading towards getting a new clutch. I've changed the clutch fluid regularly since I've owned it, but I think the previous owner didn't care for this car like I do. Anyway, I'm trying to decide which clutch to get. I'm all over the map on which clutch to purchase. The big reason I'm undecided is because I'm not sure if I'm going to go with F/I, which means I could go with a LS7 clutch but the heavy flywheel doesn't sound great. If I want to make sure to do this once and be ready in case I go F/I then I think a McLeod RST twin is the direction I'm leaning. If I go with the McLeod then it looks like I can use my current flywheel.
What are your opinions on resurfacing the flywheel? I'm leaning towards replacing everything while I'm having the work done, to include a Tick adj. master. I'm just curious if resurfacing is even a decent option. I don't track the car and I don't dump the clutch if that helps with your answers.
Thank you.
Old Nov 3, 2010 | 02:47 PM
slong's Avatar
slong
ACT makes a great clutch kit. I replaced my flywheel just because of the weight issue and I would hate having to tear back into it because an issue developed due to the worn flywheel. ACT clutches are expensive but have worked very well for me so far. A&A did the install for me and I have another friend that has the same one and is just as satisfied.
Here is a link if you want to check them out:
http://www2.advancedclutch.com/14239...5.7L_N_FI.html
Old Nov 3, 2010 | 05:49 PM
CHJ In Virginia's Avatar
CHJ In Virginia
I personally would never resurface a flywheel. If you do, it will also have to be balanced again. Replacements are cheap, why mess with it.
Old Nov 3, 2010 | 05:51 PM
MStrahan's Avatar
MStrahan
Thanks for the input. I was also worried about the balancing. I just forgot to mention it.
Old Nov 3, 2010 | 07:52 PM
imavettegirl's Avatar
imavettegirl
replace it.
cheaper then doing it twice if resurfaced one does not work out.
Old Nov 5, 2010 | 11:18 PM
andrewdonald1's Avatar
andrewdonald1
not to hijack the thread, but I've always wondered if the flywheels come pre-balanced.
I assume so, but I guess that assumes the internal crank etc (stock crank) is balanced before the flywheel goes on.
Therefore the flywheel must be only balanced for itself and not to accommodate any imbalance in the engine internals - correct? Seems logical.
Thought I would ask.
Old Nov 7, 2010 | 01:47 PM
slong's Avatar
slong
The set-up I bought from ACT was balanced from the manufacture. I can't say all manufactures do so..... but I would assume so.
To ?? resurface flywheel??
