How to change outside temp sensor?
Old Nov 5, 2010 | 06:09 AM
rwlc5's Avatar
rwlc5
Default How to change outside temp sensor?
Which way do you go to reach it? Do you go from somewhere in the engine compartment, or do you have to go from underneath the car?
Old Nov 5, 2010 | 07:22 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I had to change mine last year and it is located under the hood on the passenger side way down low on the side of the raditor shroud.
Mr.Bill
Old Nov 5, 2010 | 02:13 PM
00Corvette's Avatar
00Corvette
It'll be easier if you go from underneath..
Old Nov 5, 2010 | 02:59 PM
65GGvert's Avatar
65GGvert
I found it easier from above. I pulled up on the sensor and connector to pull the push pin out of a hole in the frame, disconnected the sensor, plugged in new sensor and pressed the pin back into the hole.
Old Nov 5, 2010 | 03:28 PM
Mr.Bill's Avatar
Mr.Bill
I agree, 5 minuets and I was done.
To How to change outside temp sensor?
