turn signals
Old Nov 9, 2010 | 10:00 PM
black match box's Avatar
black match box
Default turn signals
when I put on my signals eather right or left they do not always work I put on my flasher and somtimes work. ( 2000 C5) help me if you are out ,there. any sights or diagram would be helpful,( black match box)
Old Nov 9, 2010 | 10:50 PM
oh1vette's Avatar
oh1vette
Usual symptom for hazard switch going bad....do a search you'll find plenty including DIY replacement or bypass.
Here's a couple to get ya going:
http://www.kd5fx.com/HSwitch/HSwitch.htm
http://forums.corvetteforum.com/c5-g...nal-issue.html
Old Nov 9, 2010 | 10:54 PM
Qcksilverc5's Avatar
Qcksilverc5
Hey- my 2001 A4 Vert is doing the same thing with the turn signals. I have heard its the actual hazard switch that is bad and needs to be replaced because the turn signals actually work thru the hazard switch. Now the fix requires the radio/console etc be removed to replace the switch. If you do a search here it will give you more info on this. Hope I pointed you in the right direction. Cheers
Old Nov 10, 2010 | 01:09 AM
Jistari's Avatar
Jistari
Well Id recommend reading the threads above. You may be able to install a flasher bypass (the do hickey that the guys that convert to LED signals put in to correct hyperflash) right under the drivers knee panel, and avoid taking the whole dash apart.
Old Nov 10, 2010 | 03:34 PM
black match box
thanks . black match box (GINO)
Old Nov 10, 2010 | 03:36 PM
black match box
thanks for the info. I think I will do that. black match box (GINO)
To turn signals
