[Z06] Replica wheels?
Old Nov 11, 2010 | 05:47 PM
RedZMonte's Avatar
RedZMonte
Default Replica wheels?
How good are the replica wheels? any wheel guru's have any input? looking to do a 18"/18" setup and Discount tire has chrome Z06 replica's for $130 ea. Are they Cheap and bend easy? ive bent a few after maket wheels with low profile tires in the past (really low profile) i just wanna make sure im not pissing away the money or if im better off finding a set of stock Speedline's?
S
Old Nov 12, 2010 | 12:02 PM
RedZMonte's Avatar
RedZMonte
Anyone run these? Good? Junk? For $131 i would think they are cheap and probably bend easy... but you never know maybe they are cheap but decent wheels....
http://www.discounttire.com/dtcs/fin...7685&rc=CODINT
Old Nov 12, 2010 | 01:43 PM
RC45's Avatar
RC45
$130 x 4 = $520.
You can buy a used set of OEM wheels fo rabout $400 to $500. A scratched up set should be $350 to $450.
Old Nov 12, 2010 | 01:46 PM
earthman01's Avatar
earthman01
Most replica wheels are much heavier than stock, a concern if you are thinking of using your car on the track.
Old Nov 15, 2010 | 03:03 PM
RedZMonte's Avatar
RedZMonte
no planing on tracking the car (other then a few rec days for fun). BTW im looking for 2 of them, don't need all 4... Im planing on running 18/18" setup and powdercoating them to match.
Thanks for the reply's
Old Nov 15, 2010 | 04:18 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Its not just a situation you will feel at the track.
I just drive my Z06 around town and felt a HUGE reduction in overall performance of my car when I got a cheap set of aftermarket wheels. I later found out that I added +10lbs per wheel with the cheap setup. That's +40lbs of unsprung weight I added. My car honestly felt very sluggish in acceleration, turning etc... Everything about the car's performance felt reduced. I felt sick to my stomach that I payed money to reduce my car's performance. I "honestly" felt a difference in the car pulling out of my driveway the first time with the new setup. I could feel the clutch engaged differently, and I had to slip the clutch more to get the car going. I drove on the new wheels for a week, and put my original Z06 wheels back on. I was FLOORED at how much performance I got back out of my car. It felt like I just added a cold air kit, and my turn in felt much more crisp.
I sold that cheap wheel setup the next week and took a big hit on the resale.
My advice... If you must have chrome, then buy a set of OEM Z06 wheels, and have them chromed. Your still adding weight to the factory set of wheels with the chrome, but at least your not adding +10lbs each wheel. I think I heard some say you will add 2-3 lbs per wheel with them chromed.
Learn from my mistake... Do your homework and you will not be disappointed.
The CCW setup I later bought I did my homework on. My new CCW's were between 2-3 lbs heavier. I then compensated with lighter continental tires. That brought me to about the same weight as the factory Z06 setup. I felt NO performance reduction when I put these on. I will never buy new wheels/tires without doing my homework again.
Factory Z06 setup =
Front
...19.2 lbs (02-04 Z06 Front 17x9.5)
...29 lbs(265/40-17)(Goodyear Eagle SC)
...48.2 lbs Total
Rear
...21 lbs (02-04 Z06 Rear 18x10.5)
...33 lbs (295/35-18)(Goodyear Eagle SC)
...54.0 lbs Total
CWW - SP500 19/19 setup=
Front
...22.5 lbs (19x10 Front SP500)
...26 lbs (275/30-19)(Continental ContiSport 3)
...48.5 lbs Total
Rear
...23.5 lbs (19x11 Rear SP500)
...28 lbs (305/30-19) (Continental ContiSport 3)
...51.5 lbs Total
Toque
Old Nov 15, 2010 | 04:34 PM
RedZMonte's Avatar
RedZMonte
thanks for the info. Im hoping to find a set of stock 18" Speedline rear wheels. The "black Chrome" is a powder coat so it will not weigh much more then a stock wheel when all said and done.
Old Nov 15, 2010 | 07:15 PM
halp's Avatar
halp
That is good information. I have heard a lot of bad info on the replica wheels. That is probably why it is hard to get vendors to give you the weight. I guess you get what you pay for.
To Replica wheels?
