Backup Camera
Old Nov 17, 2010 | 07:33 PM
TP C5's Avatar
TP C5
Default Backup Camera
Has anyone installed a backup camera in their C5? If so what camera did you use and how did you install it in the back license plate area.
Thanks in advance!
Popular Reply
Jul 8, 2021, 11:39 AM
thordac's Avatar
thordac
3rd Gear
Default Files
Originally Posted by MWWarlord
Very nicely done! I'm not currently looking to do this mod. However, I'm certain there are others on the forum who would be very interested in purchasing these from you. This is one of the better mounting solutions that I have seen.
Thank you
I posted the files on Thingiverse for people to download and print for free.
https://www.thingiverse.com/thing:4903592
If someone doesn't have a printer I'm sure we can work something out.
Old Nov 17, 2010 | 07:38 PM
Gitusum's Avatar
Gitusum
i am in the process of installing my backup camera and i purchased a boyo . it bolts to the top bolts of the plate
Old Nov 17, 2010 | 07:57 PM
doggman's Avatar
doggman
I'm interested in doing this also.
Old Nov 17, 2010 | 09:00 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I went with the Boyo 420C camera tied to a Mito GENK352 Auto-dimming mirror with integrated 3.5" display. Ordinarily the Boyo mounts to your license plate and/or frame, but I found that it doesn't fit flush with the stock frame and also covered part of the license plate, obliterating our state motto. Not wanting to hack up the frame, nor cover our brazen motto, I found an easy way to mount the Boyo.
At Home Depot, or thereabouts, you can find a steel plate/strap (about 1/8"x 1.5"x9" roughly) that already has holes drilled the same distance apart as the mounting holes on the Boyo. I placed the plate between the license plate lamps (after temporarily removing them) and hung the Boyo from the upper part of the license plate recession. Because the camera is mounted upside down from its norm, I simply removed the camera from its housing and flipped it over. Took 2 minutes.
The result is a camera that is virtually invisible and doesn't infringe on any original equipment or legalities.
I found the Mito mirror on that ubiquitous auction site as a new take-out from a Tacoma pickup at half the retail price of a new one.
With the camera wired into the backup lights and run up to the mirror, the display is only visible when the tranny is put into reverse. Bonus - the mirror is also self-dimming, which the stock one wasn't.
Old Nov 17, 2010 | 10:02 PM
_zebra's Avatar
_zebra
^^ dude, that's pretty sick! awesome job
Old Nov 17, 2010 | 11:21 PM
wcdaniel's Avatar
wcdaniel
How'd I get my backup camera on my '03 C5, it came on the Vette when I bought it. Priceless..............
Old Nov 17, 2010 | 11:23 PM
wcdaniel's Avatar
wcdaniel
Ohh yea, I forgot, very impressive installation.
Old Nov 17, 2010 | 11:26 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I have the option for a mirror
you can not only add a back up cam
but you wil also get NAv and Bluetooth
329.99 shipped
here is the pics and info on the install
http://forums.corvetteforum.com/c5-g...ll-review.html
Old Nov 18, 2010 | 12:40 AM
Patches's Avatar
Patches
Here's my install.
http://forums.corvetteforum.com/1572701634-post23.html
Old Nov 18, 2010 | 01:30 AM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Originally Posted by Patches
The song "God is watching us" came to mind.
Old Nov 18, 2010 | 04:31 AM
eldudereno's Avatar
eldudereno
Originally Posted by c5vetteguy
I
It's nice to see a real life picture instead of one that's simply been copied onto one of those mirrors/screens.
I've been thinking of fitting a camera and screen in my car as it's a right PITA when pulling up to a roundabout in a LH drive car when driving on the left here in the UK. The only way to see if it's clear is to make some slack in the seatbelt and lean forward as much as I can when pulling up to a roundabout. I cannot see at all if I've got a passenger in the car so I have to ask them if it's clear.
Old Nov 18, 2010 | 01:53 PM
mschamberger's Avatar
mschamberger
That's a fantastic setup. I've been wanting one because I have my back window tinted (supposedly only 35%), but I can't see ****e out of it at night.
Old Nov 18, 2010 | 06:24 PM
gizmominou's Avatar
gizmominou
great post
Old Nov 18, 2010 | 06:38 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
That's pretty clever, but now you have CA plates.....
Old Nov 18, 2010 | 10:55 PM
BitViper's Avatar
BitViper
Here's how i did mine.. the camera mounts up out of teh way and didnt need to have any visible holes drilled.. you do need one thru the trunk
Metal mount made from some strap I had lying around
Back side of the reverse lights
I drilled holes to match up with the pegs in the back
The brace in place w/o the camera mounted
Then mounted teh camera to teh bracket....
Old Nov 18, 2010 | 11:02 PM
Patches's Avatar
Patches
Not yet - but soon. I will figure out an alternative. It's what I do.
Old Nov 19, 2010 | 09:18 AM
c5vetteguy's Avatar
c5vetteguy
In this picture, the backup display appears semi-transparent, but it actually isn't. Must be the camera and/or light angle. As far as night vision goes, I also beefed up my reverse lamps with the brightest LEDs I could find. No problem seeing at all whilst backing.
To Backup Camera
Old May 20, 2013 | 04:57 PM
Ricbear's Avatar
Ricbear
[/QUOTE]
Does the mirror have map lights built in? or what did you do about the map lights.
Old May 20, 2013 | 05:01 PM
heavymetals's Avatar
heavymetals
I did backup and front (I was always hitting parking blocks!).
Old May 21, 2013 | 09:13 AM
c5vetteguy's Avatar
c5vetteguy
Map Lights? We don't need no stinking map lights!
I never used the ones I had, so I'm not missing them. This mirror doesn't have them.
