Where is the best place to splice in to hook them up? (I just want them to come on while the hood is open - so I guess I may need to add a spring/pressure switch somewhere)?
I added some to mine but spliced them in to the remote cove light setup I got from JW motoring so I can activate them with a key fob that comes with the kit. Has a few different flashing/steady modes.
Here's a few so-so pics.
Here's where I put the LED strips.
Were you at the Extavetteganza in Slidell? Nice looking car you have there
Rob
Thanks....yes I was there...great show except for that huge rain shower that happened just as I was inside getting something to eat! Had to run out with my food, throw it in the front seat and hurry and put the roof back on before it got too soaked!
IMO the 2 best ways to hookup underhood lights are to:
1) tap the existing underhood lighting circuit
2) install a manual activation switch.
How does the factory map light work? Is it a mercury switch that maybe turns the light on when the hood is lifted and then somehow the BCM senses that and starts a shut off timer?
Ahh yea i had to run out and put my hood down and saved someone's C5 vert from getting rained in. I remember your car very nice a few mods that I am looking to do that you have done
I mounted a couple led spotlights where the center 2 hood pad retainers are located. enlarged the holes and mounted the leds behind the pad. Relocated the retainers next to the leds. I wired them into the back of the factory hood light so they operate when the hood is open. Always check the hood to p/s resevoir cap if using these spotlights.
I siliconed a superbright strip under the red halltech stinger and was amazed at how "on fire" it looks!
Here is a picture of how I wired them into the back of the underhood light. Soldered the wires directly to where the factory bulb is located.
that is correct. if you just tap into the wiring going to the light it will be on all the time.
I added some strips to mine and installed a small mercury switch under the liner and ran the wires where they can not be seen unless you know where to look for them.
Went by your photo and installed my LED OZNIUM Strips in the engine bay tonight using your soldering diagram/photo. Everything seems to be working perfect! Even retained the stock bulb functionality (but I am looking for an LED replacement that is the same color temperature as the NATURAL WHITE LEDS I just installed).
Hi All,
What purpose does that push switch located on the Wiper Door Actuator housing by firewall in A 72 c3 and where does it connect under dash?
Dougtov
