A4 question
Old Nov 20, 2010 | 04:06 PM
Big Jay E's Avatar
Big Jay E
Default A4 question
My tranny is having lazy shifts into third and forth gear. I have gotten used to it and lift the throttle to let it shift. Recently had new fluid and filter done at a reputable shop and it helped some.
They told me that when they do a tune, one thing it does is raise the line pressure in the trans. I have noticed that under full throttle acceleration, the trans shifts fine.
So I am thinking of taking it in and having them raise the line pressure and see if that helps. Anyone had any experiences with this?
Jay
Old Nov 20, 2010 | 04:54 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I had that same problem a few years ago. It was not long before it got worse. Then it started slipping. Then a new RPM stage IV tranny went in.
Good Luck
Old Nov 20, 2010 | 04:58 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Good Luck
On my first coupe, I had an A4 and it sounds alot like what I went through and ended up having to replace tranny. Hope it turns out to be nothing.
Micah
Old Nov 20, 2010 | 05:01 PM
99 vett babycar's Avatar
99 vett babycar
you can try the tune but don't invest a lot of money in it. It will probably make the shifts feel better for a while. In the mean time start saving up for a RPM transmission- you are going to need one.
To A4 question
