Need help figuring this out
Old Nov 23, 2010 | 03:10 PM
NikiQ's Avatar
NikiQ
Cruise-In 9-10 Veteran
St. Jude Donor '07-'08-'09
Default Need help figuring this out
I have a 2004 vert that is my driver. The car has been trouble-free and I absolutely love this car. I installed a cam a few months ago, which made it that much better.
A couple of weeks ago when I went out to start the car in the morning, I could hear a "chirp", which would sporadically come and go. The sound never varied speed, regardless whether it was stopped or going at highway speeds. The car ran fine other than the sound. I thought perhaps it was the belts, so I changed out the belts and the tensioners, checked the fans and shrouds, but still had the same chirp.
Metal has been discovered in the oil filter. I know this is not good.
Further diagnostics are being performed on the car to try to figure out what went wrong.
I've got some knowledge about the runnings of my car, but want to take this opportunity to learn even more.
What else could it be?
Old Nov 23, 2010 | 03:35 PM
dougbfresh's Avatar
dougbfresh
Harmonic balancer? Does your wobble??
Old Nov 23, 2010 | 03:36 PM
NikiQ's Avatar
NikiQ
Harmonic balancer appeared to be ok. No wobble and was solid.
Old Nov 23, 2010 | 03:40 PM
dougbfresh's Avatar
dougbfresh
Get a stethescope and start investigating.
Old Nov 23, 2010 | 05:48 PM
DFWLCJ's Avatar
DFWLCJ
Beth
Could be valve spring related issue? Recall Jim's problem...started as valve spring issue.
Metal shavings in oil pan...possibly from push rod/spring(s)/stems/retainers/seats?
Generally not good regardless of source...
Did you change springs with the cam?
I'd run it by whoever did the work.
Since its a DD, how many miles since the cam work?
Old Nov 23, 2010 | 05:51 PM
jda67gta's Avatar
jda67gta
St. Jude Donor '09
So the sound does not vary with any change in RPM?
Motor mounts? Exhaust rubbing against something?
Strange days indeed........
Old Nov 23, 2010 | 06:43 PM
RFP's Avatar
RFP
St. Jude Donor '09
Does it 'chirp' whether sitting or driving?
Could it be a noise from the heat-A/C system?
What is the frequency of the 'chirp' (once a second, ten times a second, whatever)?
Is the 'chirping' frequency constant?
Does it sound 'electronic?'
How loud is it?
Old Nov 23, 2010 | 07:16 PM
NikiQ's Avatar
NikiQ
I eliminated the heat/a/c, so it's not that. The sound is constant whether I'm not moving, or at highway speed. The sound has gotten louder over time, but at infrequent times but when I hear it, the frequency is about couple of times a second. I haven't been able to determine any one thing that will get it to occur. Not an electronic sound. I thought the sound was coming from the belts, but I changed them and it still happened.
Old Nov 23, 2010 | 07:19 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Post up a video, that would let us know a little better, good luck, and yes i also have a chirp once in a while.
Old Nov 23, 2010 | 07:40 PM
rkboz's Avatar
rkboz
One thing that would stay the same no matter the rpms would be electric fans
Old Nov 23, 2010 | 08:10 PM
BobAruba's Avatar
BobAruba
Important: Are the metal pieces shavings or do they have some form?
Bob
Old Nov 23, 2010 | 08:13 PM
00Corvette's Avatar
00Corvette
You said you replaced the tensioners...
Did you also replace the pulley on the BOTH tensioners? Did you also replace BOTH idler pulleys?
What brand of belts are you using?
Old Nov 23, 2010 | 08:31 PM
RFP's Avatar
RFP
St. Jude Donor '09
Of course, had it been belts or tensioners, the chirp would have varied proportionally with engine RPM... but new belts and tensioner(s) are always nice to have
Old Nov 23, 2010 | 09:43 PM
tricep's Avatar
tricep
St. Jude Donor '09
I had the same thing. Replaced both tensioners (one at a time about a month or so apart)-- it ended up being the idler pulley.
Old Nov 24, 2010 | 07:42 AM
NikiQ's Avatar
NikiQ
Right before I replaced the belts and tensioners, at the recommendation of my mechanic, I did start the car up briefly with the belts disconnected and the sound was still there. I think I've ruled out anything having to do with the belts or tensioners.
I finally had it taken to a very reputable shop. They heard the sound, and were the ones that found metal in the oil filter. Now I'm just waiting for final diagnostics for a cause. With the holiday weekend, I won't be able to see it until next Monday. I'm wondering if it had anything to do with the cam install.
Old Nov 24, 2010 | 08:01 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I"d send an oil sample out to be analyzed. That may tell you where the metal is coming from.
I just find it odd that the chirp doesn't vary with speed. It is possible that the chirp and the metal in the oil are unrelated and that you simply found the metal while looking for the chirp. Without the oil information I would have said look at the headers/cats/exhaust and see if it is rubbing.
Has the oil been changed since you did the cam work? I don't mean that same say, I mean days or weeks after? It is possible the metal is from the cam work.
GL
Old Nov 24, 2010 | 08:23 AM
U17's Avatar
U17
Any new metal part introduced to the engine will have "sharp" edges from machining... Even parts that are deburred or camfered will have some little pieces that will stick out and be worn off from rubbing... Changing oil and filter after engine work is a good idea, maybe a couple of times...If your "chirping" is not changing with RPM look for "constants" with the engine running...
Old Nov 24, 2010 | 09:12 AM
sfc rick's Avatar
sfc rick
No change with RPM's eliminates engine related causes. Stop looking in the engine, unless you don't care how much money is wasted. If a shop is now telling you there is metal in the engine filter(where it belongs) and you get a rebuild and the chirp is still there....you may feel violated in an obscene way. Especially if your engine runs as smooth as butter now.
Old Nov 24, 2010 | 12:08 PM
Venomous's Avatar
Venomous
Where is the car located? What color was the metal? Copper, silver? I may be in the area this weekend and wouldn't mind checking it out as well as meeting another member and thier sweet rides!
To Need help figuring this out
