Power Door Lock Latch
Old Nov 24, 2010 | 01:59 AM
C5015's Avatar
C5015
1st Gear
Default Power Door Lock Latch
I’m having a problem with my 98 driver side door lock, it locks/unlock perfectly using the remote control but when I’m using the key it’s doing nothing it seems loss.
What do I have to change?
Is it only the left Actuator (#25664288)? --> found in ebay (46.90 $)
Is it Power Door Lock Latch (#10346748)?
Or both attached? --> found in MAM (219 $)
Old Nov 24, 2010 | 06:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You need to open up the door first and see what's going on with it before just dumping money in there. Easy to do.
Old Nov 24, 2010 | 01:28 PM
DeeGee's Avatar
DeeGee
It's normally the other way around. Normally the fob door lock fails but the manual side works
Post up your codes and we can take it from there.
Old Nov 24, 2010 | 04:05 PM
C5at57's Avatar
C5at57
PM sent.
Old Nov 24, 2010 | 09:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Pull the door panel and check the two rods and make sure they are hooked up correctly.
To Power Door Lock Latch
