Size Matters
Old Nov 24, 2010 | 09:35 PM
VETSTYL's Avatar
VETSTYL
Default Size Matters
I finally found THE RIMS to die for Talked to two different distributors today and they both said that they will fit a C5
The only problem They only come in 20s.
I'm lowered on stock bolts. I've seen many posts saying that 20s are terrible but then again I've read postings of 19 and 20 staggereds.
Am I asking for a sizeable amount of trouble if I go 20s all the way around.
Old Nov 24, 2010 | 09:40 PM
WildTurkey's Avatar
WildTurkey
I think so....20s on the back are definitely doable, but I'll I've heard about 20's on the front are RUB issues. If you really want 20s, I would limit it to the rear and go 20-19
Old Nov 24, 2010 | 09:51 PM
jrose7004's Avatar
jrose7004
What wheels are you looking at?
Old Nov 25, 2010 | 02:02 AM
JETZ's Avatar
JETZ
Go 19/20.
Big wheels make stock brakes look weenie, so if you plan on upgrading to BB's in the future you need to order your wheels with that in mind. You can't run BB's on wheels not built for them, as the won't have the clearance.
Old Nov 25, 2010 | 02:21 AM
memphis_vette's Avatar
memphis_vette
i run 18 and 20
Old Nov 25, 2010 | 07:13 PM
I think the real problem with going with the 20s is the reduced sidewall height that is available. I ran a set of 19/20s on my '00 for a while and always worried about going over a deep pothole.
To Size Matters
