Vibration...Header covers?
Old Dec 3, 2010 | 10:34 AM
JeepZJRubicon's Avatar
JeepZJRubicon
1st Gear
Default Vibration...Header covers?
Hi. I'm new here. I have C5 Manual LS1 Vette. Anyways, I have a vibration noise coming from the engine bay after the engine warms up for about 25 minutes...only in the 1000-1500rpm range under light load....could the header covers be causing this when they expand with heat? Anybody drive around without these covers or would the heat damage other components? The vibration must be related to something expanding under heat, because it is not present when the motor is cold. Anybody have similar issues? The vibration can be heard but not felt, so I'm sure it is not driveline related...Thanks!
