[Z06] Gears Problem
Old Dec 6, 2010 | 09:34 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Default Gears Problem
Hello people. I'm new here to the forum. I just bought an 2000 Corvette Z06 delco/mongoose. For some reason my gears been sticky which means that my gears are not smooth and hard to go in gear. Any help on fixing this?
Old Dec 6, 2010 | 10:07 PM
VCUFAN's Avatar
VCUFAN
I think you were duped on the '00 Z06. Did you check the fluid? Is it all gears? Need some more info and better explanation.
Old Dec 7, 2010 | 02:15 AM
slvrzo6's Avatar
slvrzo6
Uhhh, Yeah.. No Z06's were made in 2000. C5 Z06's were only made between 2001-2004..
Old Dec 7, 2010 | 05:17 AM
winters97gt's Avatar
winters97gt
Yeah, that sucks. You don't have a z06. You might have an FRC, but not a z06.
Old Dec 7, 2010 | 03:48 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Only C5Z's were 2001-2004'
Try Mobil 1 Synthetic Dexron III, worked for me.
On the bottle it says for GM vehicles 2005 and older. The 2006 and newer stuff is the Dexron VI, bottle looks the same, not good for our older trans.
Old Dec 7, 2010 | 10:20 PM
chrisk92's Avatar
chrisk92
Yes, I know z06 wasn't made in the 2000 it was a swap motor with a delco/mongoose package. Ever since I bought the car my gears been sticky like not going into gears its keep popping out and my reverse gears is messed up also does the same problem I change my fluid and I dont know what the problem with it maybe I need a new clutch or something.
Old Dec 7, 2010 | 10:23 PM
chrisk92's Avatar
chrisk92
How much is one for the bottle gal wise?
Old Dec 7, 2010 | 11:07 PM
winters97gt
Doesn't sound like a gear problem, but a tranny problem. Not sure what a mongoose package is, but you probably have a M6, and not a m12 tranny.
Old Dec 7, 2010 | 11:41 PM
MUKAK's Avatar
MUKAK
obviosly not a Z (imitation) and when did did a "mongoose swap" they only change the motor... not the tranny am sure... u still prolly have a M6 not an M12 like in Zs
Old Dec 8, 2010 | 08:27 AM
machz800ps's Avatar
machz800ps
You need to take you car to a shop and tell you, I have a feeling your looking at a trans rebuild, if lucky you have a clutch issue, again if you are not a wrencher take the car to someone.
Steve
Old Dec 8, 2010 | 09:06 AM
chrisk92's Avatar
chrisk92
I believe you are right cause I drove a regular Z06 and it doesnt feel like this at all.
Steve
I can do the work myself I just need to know what wrong before I blow my money on things that I dont need to be fix. My thoughts are going towards the tranny now. It the same response I be getting.
Old Dec 8, 2010 | 09:48 AM
machz800ps's Avatar
machz800ps
Start with the clutch and see if that fixes it then work your way back to the trans does not hurt to replace everything while your under there
Steve
Old Dec 8, 2010 | 10:27 AM
Jim in Mich's Avatar
Jim in Mich
Check your clutch fluid, I bet it's black and nasty. Replace with DOT 4
Old Dec 8, 2010 | 12:56 PM
chrisk92's Avatar
chrisk92
Steve
Okay, I will start doing it when I have time off.
Old Dec 9, 2010 | 12:26 AM
winters97gt
Unless you have a remote bleeder, that won't do much of anything. The entire system needs to be removed and cleaned if you haven't been keeping up with changing the clutch fluid frequently.
Old Dec 9, 2010 | 07:57 AM
chrisk92's Avatar
chrisk92
I'm the third owner of the vehicle so I dont know if it was well kept. I'm going to do inspection see what else needs to be fix before it cause more problems down the road. Thanks for the advice everyone.
Chris
Old Dec 9, 2010 | 04:28 PM
84REDCROSSFIRE
Not so
Mine was black as death, and it took a few times and days to get it clear. Now it stays clear, Change it twice a year.
To Gears Problem
Old Dec 9, 2010 | 06:27 PM
Jim in Mich
Just suck it out , refill, pump the clutch, repeat till fluid stays clear.
Old Dec 11, 2010 | 11:01 PM
James92's Avatar
James92
I changed my clutch fluid 15 times before it finally stayed clear.
Old Dec 13, 2010 | 05:08 PM
76 VETTE's Avatar
76 VETTE
