GM Splash Guard Install
While my Vette was at a Corvette shop in Tulsa having things like headers, rear black out and other things done I had them install the Lewis C5 splash guards, The shop told me that's the best they can do, Looks like crap, So, I am removing them and trying to sand them so I might get a better fit, No luck yet.
While in the shop, they painted them Yellow like the car, so using the Black silicone is out, maybe I will try the clear. Double side 3/M tape won't hold because the fit is so bad.
L5 Guard after painting and ready to install
Installed on frt.
Note the fit, Tape will not hold in place
Rear Guard
Rear Gap, Needs to be sanded or filled.
Frt, Guard where tape will not hold in place.
Now to find something to fill and hold them in place, Sanding them is not getting me anywhere fast.
Yours looks just like mine, but mine to stick on the top side and I've got a little black screw in the top holding the top up.
For yours I would say you need some more trimming on the top to get that bottom to fit more snug. You may also need to make some long strokes to make it smooth. I had a dremel so it made life a lot easier. Don't worry there were times when I thought I had them totally screwed up. Just take your time and it will be worth it.
