What Pads Should I Get
Old Dec 26, 2010 | 03:42 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default What Pads Should I Get
I received a set of drilled and slotted rotors for Christmas and I will be putting new pads on at the same time. My question is what pads should I get? The car is not a daily driver ('01 with 35,000 miles) so I don't see the need for top of the line racing pads, but I don't want a set of cheap pads either. The rotors are GM with the center hub powder coated.
I also will be changing out the sway bars for the Z06 Z51 as well as the metal end links.
Old Dec 26, 2010 | 04:11 PM
2001yellow/redC5's Avatar
2001yellow/redC5
I have the same GM drilled and vented rotor. Hawk pads are great!
Low dusting on the rims too. $178.00 front and rears
1997-2010 Corvette Hawk HPS Brake Pads HB248F.650 C5-C6 and HB247F.575 C5-C6
* Ferro Carbon
* 20-40% More Stopping Power
* Aerospace and Motorsports Severe-Duty Friction Technology
* Extremely Low Dusting
* Best Fade Resistant
* Virtually Noise free
* High friction/torque hot or cold
* Gentle on rotors
* Extended pad life
Old Dec 26, 2010 | 04:13 PM
D C's Avatar
D C
USMC (retired)
I would go with Gene Culley and their Hawk HPS pads
Old Dec 26, 2010 | 04:17 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I run Hawk HPS on my drilled/slotted rotors and love them.
http://www.shop.jwmotoring.com/produ...&categoryId=41
Old Dec 26, 2010 | 04:18 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Hawk HPS is a great choice
Old Dec 26, 2010 | 04:35 PM
Oldvetter's Avatar
Oldvetter
I run HAWK HPS on my drilled and slotted rotors and love them. Less dust than stock Coupe Pads and more stopping power than ZO6 pads.
Old Dec 26, 2010 | 04:49 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
I also have Hawk HPS with drilled and slotted rotors. You can't beat'em....
Old Dec 26, 2010 | 04:57 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Another vote for Hawk HPS. Gene has great prices on these. What ever you do, do not put ceramic pads on. I had the ceramics before the HPS. You would not believe the difference in stopping power.
Old Dec 26, 2010 | 08:48 PM
Yes, the Hawk HPS pads would be a very good choice.
Old Dec 26, 2010 | 10:00 PM
redrckt97's Avatar
redrckt97
one more vote for Hawk HPS .. I've got them with stock rotors and like them very much - zero squeal, Very low dust and way better performance when pushed hard.
Old Dec 26, 2010 | 10:31 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I have the Hawk HPS,,,from,,,guess who? Been on a couple of weeks and I am very happy!
Old Dec 27, 2010 | 10:15 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Check out the Carbotech 1521, I offer a 7% forum discount contact me at 216-780-8825.
Front $144 Rear $124
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Dec 27, 2010 | 05:04 PM
webelo's Avatar
webelo
Whatever you do, stay away from the Brake Performance pads. They're friggin' awful in terms of the amount of dust they produce.
Old Dec 27, 2010 | 06:18 PM
WKMCD's Avatar
WKMCD
I ordered Carbotech 1521's today.
Old Dec 27, 2010 | 09:48 PM
Carbotech Adam
Supporting Vendor
http://forums.corvetteforum.com/c5-t...brake-pad.html
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To What Pads Should I Get
