C5 Rattles
Old Dec 28, 2010 | 07:07 PM
Ashc2025's Avatar
Ashc2025
Default C5 Rattles
Since the car's going to be parked a while I'm hoping to cure some rattles and shakes in the car.
What I'm looking for is common rattles, clinks, and shutters and their fixes. I've only had my vette a year and don't know where to start. My problems are:
Rattle behind the dash cluster
Rattle in the exhaust on shift
"Marbles in a can" sound from the tranny/diff.
What else can you think of to add to the list?
Old Dec 28, 2010 | 07:18 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
marble sound is "normal" ....I can't see why the could not have made it without ....bet Nissan would have.
Old Dec 28, 2010 | 08:03 PM
Qwik01's Avatar
Qwik01
I've got a chirp/squeeky sound coming from the rear passenger area of my car. Its very annoying and I can't pinpoint what is causing it. .
Old Dec 28, 2010 | 10:51 PM
VETSTYL's Avatar
VETSTYL
Default Glue
I've read that some forum members have glued parts together to reduce/eliminate interior rattles. I would be interested in this procedure.
Old Dec 28, 2010 | 11:00 PM
mcgilles's Avatar
mcgilles
mine has a rattle around the rear passenger's speaker that I haven't been able to find yet. I also have a horrible squeak from the rear suspension on the driver's side. its been driving me mad, I haven't been able to find the source. does it for 2-3 weeks after the last time the car got wet.
Old Dec 29, 2010 | 12:08 PM
This is a completely normal noise on the manual cars. As for the rest of the rattles, it unfortunately may be a trial and error process.
Old Dec 29, 2010 | 12:40 PM
Chicago1's Avatar
Chicago1
My whole car rattles so I can't pinpoint crap out. The main one that bugs me is the behind the dash rattle that the op mentioned.
Old Dec 29, 2010 | 01:03 PM
REDEVIL's Avatar
REDEVIL
I thought I had a rattle behind my dash for the longest time and could not pinpoint it. What it ended up being was the line that runs into the driver's side fuel rail cover in the engine compartment right in front of the driver that was hitting the firewall and making a rattle. I zip tied it away from the firewall and no more rattle. I would have bet a hundred dollars that it was coming from inside the dash, but it sure wasn't.
Old Dec 29, 2010 | 01:15 PM
Marine One's Avatar
Marine One
Been real lucky with this car. Very few rattles so far.
Old Dec 29, 2010 | 01:58 PM
Toms02C5's Avatar
Toms02C5
Old Dec 29, 2010 | 04:24 PM
C02VETTE's Avatar
C02VETTE
You should try driving by the mall and see if it goes away.
Old Dec 29, 2010 | 05:46 PM
NatB's Avatar
NatB
Exhaust rattle/jingle may be due to H-Pipe. An X-Pipe will cure this.
Old Dec 30, 2010 | 12:17 PM
Ashc2025's Avatar
Ashc2025
I had the same thing, when I removed my seats and re-installed them (stereo wiring) the chirp went away. I'm assuming something re-aligned in the latch mechanism or the seat was slightly sliding on a bolt.
Old Dec 30, 2010 | 12:21 PM
Ashc2025's Avatar
Ashc2025
Think so? does the H-pipe have a baffle or just inadequate support. Always though about an X-pipe. The popping sounds reminds me of my buddy's GTO and I can't have that
Old Dec 30, 2010 | 12:22 PM
Ashc2025's Avatar
Ashc2025
I'm definitely going to look
To C5 Rattles
