Optima Red Top (again)
Old Dec 31, 2010 | 02:58 AM
Virtual Geezer's Avatar
Virtual Geezer
I have had excellent service from AC Delco batteries in the many GM cars I've owned over my 60 years. See no reason to change.
Old Dec 31, 2010 | 03:02 AM
DeeGee's Avatar
DeeGee
If your battery is discharging that quickly you have a drain which you need to find. There are some common problems which cause it. So many problems here are the car not the battery. Even dormant the C5 pulls 20MA.
Take a look at this recent thread. I offered some thoughts at post # 10 about how to track down a parasitic drain. It may help.
http://forums.corvetteforum.com/c5-t...goes-dead.html
The Red Top is an AGM battery. Many of us chose them when there were problems with the OEM batteries leaking as they are virtually leak free. Thankfully those days are gone as the early OEM batteries have all died a death. The down side is, as you say, they dont tolerate discharging so they need to be looked after on a car like the C5. I'd always recommend a battery tender for a non daily driver. There's no reason why a Red Top won't give you years of service if you top it off with a tender regularly. I have a Yellow Top and it's going strong after 4 years in my weekend car but it gets hooked up to a tender if the car sits for longer than 2 weeks.
Ultimately a battery is a battery, AGM or lead acid. If you dont look after it and understand its strengths and weaknesses it will die. Our car unfortunately eats batteries.
Old Dec 31, 2010 | 03:08 AM
rodsvet's Avatar
rodsvet
You guys are scaring me!! I put my red top in 1-5-05. 6 years of good service and it's still working great. If I only get one more day out of it then it's been good for me. Sorry for your bad luck though. I think in this day of "No pride of workmanship" no matter what we buy, there will be good ones and sh&t ones. Have a Happy New Year guys!! Rod
Old Dec 31, 2010 | 09:30 AM
rebelheart's Avatar
rebelheart
I used a red top in my racecar,it was always on a CTEK but barely ever lasted 3 months.Present diehard has lasted 3 years and had never been charged. New owner still has it in the car.
Old Dec 31, 2010 | 10:57 AM
TP C5's Avatar
TP C5
Originally Posted by ZFLASH
Man this thread is a few hours too late,just bought a red top this afternoon. Are there much problems when used as a DD?
I had a red top for years and never had a problem with it. I moved up to a yellow top after that!
Old Dec 31, 2010 | 11:12 AM
vinceg's Avatar
vinceg
I have a red top in my c4 I installed it in 2006 never a problem. I installed one in my 03 z18 mos. ago and drive it about 2 times a mo. no problems.
Old Dec 31, 2010 | 11:27 AM
christian79's Avatar
christian79
Get rid of it NOW..... ANY battery you have to coddle this much is CRAP. My OEM lasted 9 YEARS! My Optima in my DD Vette lasted 35 Months. In reality it started to fail in the spring of 2010. I hate the battery so much that I would not even sell the new replacement to another Vette owner b/c I did not want to pass along that kind of garbage.
Old Dec 31, 2010 | 11:28 AM
christian79
I agree and thats what I will buy WHEN my Red Top dies!
Old Dec 31, 2010 | 11:45 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Old Dec 31, 2010 | 12:13 PM
juriah's Avatar
juriah
OK after reading all this about dead batteries, I had to go out and try mine. Its hasn't been started in 2 1/2 to three weeks, my autozone battery fire right up.
The only time I have ever had issues is when I had a loose terminal. No hassles at all from Autozone about changing the battery out in warranty.
Old Dec 31, 2010 | 12:44 PM
manley845's Avatar
manley845
Autozone's batteries are made by Johnson Controls (Advance Auto uses the same manufacturer); if you get a "premium" battery from Johnson Controls, i.e. Duralast Gold or Advances Titanium, you will have years of trouble-free service.
I don't have personal issues with Optima batteries, and for the sake of having a "cool" batter in my car I'd love to use one. But, I have had trouble with the 3 Optima batteries I've owned and have seen many of them get returned for being defective. I don't think they are junk by any means, I feel that they are unique batteries and simply require special care and maintenance. If they become drained, you want to avoid high amp charging as this appears to be a source of failure.
AC Delco OEM batteries seem to fail consistently at the 2 year mark (on DD cars). But, I have seen the replacement Delco's last many years.
Good luck on the battery trouble, let us know how things turn out.
Old Dec 31, 2010 | 12:45 PM
csexton's Avatar
csexton
Tender is always on my Red Top
Chuck
Old Dec 31, 2010 | 01:24 PM
  #33
TN Vette's Avatar
TN Vette
The Red Top is an AGM battery. Many of us chose them when there were problems with the OEM batteries leaking as they are virtually leak free. Thankfully those days are gone. The down side is, as you say, they dont tolerate discharging so they need to be looked after on a car like the C5. I'd always recommend a battery tender for a non daily driver. There's no reason why a Red Top won't give you years of service if you top it off with a tender regularly. I have a Yellow Top and it's going strong after 4 years in my weekend car but it gets hooked up to a tender if the car sits for longer than 2 weeks.
I looked at a new 2008 Z06 a couple of years ago that was in the showroom and the salesman went to turn the key and it was DEAD.
He even looked under the hood to make sure the battery hadn't been disconnected. The car had sat for ~40 days in the showroom without starting and the battery was completely dead.
My point is that these cars are hard on batteries and the owner of the car has to buy the battery that suits how often they drive the car or put a Tender on it like I do.
I've had my Optima Red top since this spring and if the car sits for 2 or more weeks. I put the CTEK tender on it as a precaution.
Old Dec 31, 2010 | 01:48 PM
  #34
Jistari's Avatar
Jistari
This comes up so often I just dont have the strength to type it out...again
The short version:
We started using Red Tops because of a leaking problem on the oem delco's. That went away, forget about it, no battery you can buy today is going to leak.
The original spec for the C5 stated a 90 RC, time and experience has shown that to be on the low side of what works, you will do a lot better (and have many, many fewer headaches) if you select a battery with a 120 RC.
All batteries (even from the same manufacturer) are not the same and the C5's we put them in and the way each car is used and stored vary just as wildly. This accounts for the disparate stories we hear of people getting great service from their red top while others have nothing but problems.
Bottom Line:
The Optima Red Top is probably not the best battery for a C5.
Any battery with a 120 RC (even the cheapest one you can buy) will probably do better.
With this car, a float/conditioning charger is always a good idea and will not only save you aggrevation on starting, but will aslo keep the battery/electrical system in a state where you will avoid a whole host of other (colum lock, Active Handeling, DIC) issues.
Just my .02 c.
Old Dec 31, 2010 | 01:53 PM
  #35
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
My car had an Optima red-top in it when I bought it well over three years ago. My car lives outside and has seen snow and 25 degree temperatures and a couple of weeks between drives at times.
Not one single problem.
Old Dec 31, 2010 | 05:17 PM
  #36
luvlake's Avatar
luvlake
Had a yellow top on my 99 FRC. Very happy. I have a factory battery in my 08 vert, going to replace after 4th year with yellow top. I have heard some bad reports on a red top, if you don't drive a lot, and run a maintainer, get a yellow top.
Old Dec 31, 2010 | 05:29 PM
  #37
killain's Avatar
killain
Oldtimer
Default Red top Batteries ?
Originally Posted by 99XTC
it seems red tops are crappy batteries for these cars.
I had one in mine and it gave me nothing but start up problems.
Well it must be something you've got it hooked up to like a after-market Amp system or some other drain on the battery. If you leave your GPS unit left in the power outlet, and it went dead on the guy. but once he disconnected it there was no battery issues. I have had mine for four years now and I never had a single problem. I like others above, put my float charger if I'm nor using the car for two or three weeks.
But I know from past experience if you leave a battery on the cold concrete it'll go dad in nothing flat. Put a rubber door mat and hook up a 1.5 amp charger and it'll be fully charged in a few hours or overnight.
To Optima Red Top (again)
Old Dec 31, 2010 | 05:49 PM
  #38
Vettmann17's Avatar
Vettmann17
I've read many posts on this forum who have had many problems with Optima batteries. So when it was time for me to get a new battery I went with a Duralast Gold from Autozone. I've had it in for about a year now and it has performed perfectly, from the heat of the summer to the bitter cold it provides a steady 14+ Volts and my Vette starts stong even after sitting for two months with no problem at all. I paid about $80.00 for it and it has a 5 year warrantee. I Don't mean to sound like a commercial for it but I am very happy with it and it didn't cost me a lot at all. I don't think that a battery that costs over $100.00 should require a battery tender sitting unused for a month or two, that to me is unacceptable for what should be a premium quality battery. Just my .02
P.S. Have a Happy New Year Folks!
Old Dec 31, 2010 | 05:56 PM
  #39
Mr.Bill's Avatar
Mr.Bill
You are a very lucky man if your Vette can sit for 2 months and still start, There are a lot of Vettes no matter what battery you have that can't sit for 2 months. The C5 consumes volts while sitting.
Old Dec 31, 2010 | 06:11 PM
  #40
Vettmann17's Avatar
Vettmann17
All I can say is that the car sat from Jan to early March last year and the car started right up, no problem. I've had similar luck too with the original AC Delco. Believe it or not I got 8 years of life from the original battery and never had to put a charger on it once. Even when I replaced it it still provided enough volts and did start the car OK but I felt it was getting a little weak and I didn't want to push my luck so I bought a new one. What can I say maybe I'm just lucky with batteries.
Anyhow Have a Good One Mr. Bill, and you really do look like that guy from American Chopper!
